Hello Guest it is November 19, 2026, 11:01:56 AM
Author Topic: Mirror image.  (Read 10939 times)
Mirror image.
« on: July 12, 2009, 11:23:33 PM »
Hi all,
Just got my Milling machine converted to CNC using Mach3. I loaded the "Cut Arc" from the wizard, and posted the "G" code .when opening the screen to view it looks fine till I run the machine to simulate the cut(Using a Felt Marker) just to see what it looks like. the picture that the machine cut (drew with marker)is a mirror image of what is shown on the screen.
Can anyone help out as to what to do to fix this? The X and Y movements are correct and not backwards.
Thanks.
John
SolidWorks to Mach3.
« Reply #1 on: July 12, 2009, 11:29:42 PM »
 I am used to drawing parts in SolidWorks, and don't want to learn Master-Cam. How can I move the SolidWorks drawing to Master-Cam and to Mach3?
I tried to save the file as STL and DXF. anyone has the sintax for the process? any ideas.
Thanks.
John
Re: Mirror image.
« Reply #2 on: July 24, 2009, 09:57:52 PM »
Normally, MasterCam will import directly Solidworks Solid and can import Solid History too.
But don't know what version you use.
When you go in the open menu in MasterCam, specify what kind of file you want to import and select SolidWorks file extension.
In the open menu, select OPTION and Check Import solid History.
Jeff
Re: Mirror image.
« Reply #3 on: July 24, 2009, 10:21:24 PM »
Jeff,
Thanks for the reply. I will try it and see if it works. I am using 08 Solidworks and Mastercam X.
Re: Mirror image.
« Reply #4 on: July 25, 2009, 07:04:49 AM »
Thanks.
John
Are you sure? Every time I've seen this question come up, the machine has been set up backwards.
