Hello Guest it is September 22, 2026, 06:48:01 PM
Author Topic: My fireball v90 setup  (Read 19522 times)
« on: July 10, 2009, 12:37:00 AM »
hello everyone, I've been lurking for a while as a guest but now I have a machine setup. I took the easy way out and bought a fireball only because all my attempts to make my own from scratch failed bad. any who please let me know what you think ^-^
Re: My fireball v90 setup
« Reply #1 on: July 10, 2009, 12:56:14 AM »
Looks great Rich, you should be making cool things in no time. Good luck, and have fun.
  •  9,373 9,373
« Reply #2 on: July 14, 2009, 02:24:07 AM »
Thats brilliant Rich. You have a machine to be proud of.
Just one suggestion though - your dust extractor should really be located outside the work area. The filters in these things may not trap the really fine particles and there is always a risk that you would be inhaling potentially harmful dust from the MDF you cut.
I look forward to seeing some pics of the things that you have made with the machine.
« Reply #3 on: July 19, 2009, 08:57:53 PM »
I was thinking of making a wet dust collecting on the vacuums exhaust but part of the problem is space, my other thought was to vent it outside except that I'm in the corner of a basement and the only window is through two walls -_-
« Reply #4 on: August 29, 2009, 07:47:38 AM »
That's a very nice machine, should be good for PCBs and all sorts of things. Well done, you'll have fun :)
... and you won't have to go round it with a mop like mine, lol
For particles: how about a better vacuum cleaner with an HEPA filter? they'll trap pretty much anything.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
« Reply #5 on: August 31, 2009, 06:25:50 AM »
I would blow it into the lounge, within no time you will have all the space you need  >:D
Graham
« Reply #6 on: August 31, 2009, 06:41:55 AM »
  :) ;D:D
Good one Graham.
And here's a quote from some time back that would probably apply also.
          """very easy to start, costly to finish, well worth it in the end"""
Russ
« Reply #7 on: August 31, 2009, 06:42:30 AM »
Richy,
Hope your having fun with the new machine. One thing i may mention is that lather on you may want to consider
a small laminate router as they are so much more roburst than that dremel and will run more true.
Have fun and post a picture of any work of arts you do.
Hmm.......They used to call me Richy.... won't get into names.........  >:D
