Hello Guest it is November 24, 2026, 02:06:00 PM
Author Topic: Problems using G41 with G91  (Read 11368 times)
« on: July 09, 2009, 09:20:57 AM »
Having decided to move my drivers from the plastic case that they came in into a metal case so that they are screened I looked for details of the cutouts required for DB9 connectors.  I found that some G code was included for this job in the MACH3 release, in shapes.tap, BUT it is in Absolute mode and I wanted a positionless subroutine for multiple cutouts in s single program.  I did the conversion and the results were somewhat interesting :-
If the subroutine is run at the position where the toolpath has been regenerated it is almost correct, but the finish co-ordinates are slightly off, but when you move away from the regereration point and call it again you get some very interesting paths cut/dispalyed.
I am attaching a self extracting zip containing a readme file along with various implementations of the code and the xml file that I was using. MACH3 Versioin R3.042.020
I also ran it on my internet machine, demo license Version R2.63 with the default xml with very similar results
Re: Problems using G41 with G91
« Reply #1 on: July 09, 2009, 10:25:08 AM »
Try  it with 3.43, which has a different comp in it. Be aware that 3.43 may have other bugs, though.
« Reply #2 on: July 09, 2009, 08:49:57 PM »
Many thanks, 3.43 seems to do it.  I also tried 3.042.027 but that was bad.
