Hello
Guest
it is
November 13, 2026, 10:34:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Hotkey Keystrokes?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Hotkey Keystrokes? (Read 20195 times)
stringkilla
89
Hotkey Keystrokes?
on:
January 04, 2006, 08:07:12 PM »
I have another problem. I know I,m becoming a pest. I
really need to know
what keystroke's correspond to the number 33 and 34. These are the numbers in the hotkey boxes that control the Z axis jog. It seems in my panic I messed them up and now, I can't find them. I am in dire need.
I need HELP.
chad
361
When the going gets weird, the weird turn pro.
Re: Hotkey Keystrokes?
Reply #1 on:
January 04, 2006, 10:04:04 PM »
The default Mach install will be, page-up, and page-down. 33 z++ 34 Z- -
chad
stringkilla
89
Reply #2 on:
January 05, 2006, 08:52:31 AM »
I guess I might ask this obvious question. Is that with the shift button??
stringkilla
89
Reply #3 on:
January 06, 2006, 07:47:01 AM »
Yes, but what keystrokes will make that happen? I'd like to get them back, but in the mean time I've allocated the numbers 1 & 4 for Z+, Z-, respectively. In the end I need to KNOW WHAT KEYSTROKES MAKE THE NUMBERS 33 & 34 end up in those boxes
John S
111
Nottingham England
Reply #4 on:
January 06, 2006, 08:48:45 AM »
High light the box needed like Z++ then whilst highlighted hit Page up and it will insert the number 33.
If the number 33 is alreday there then iy will use page up [ no shift]
Many of the questions you are asking are basic and you really do need to sitdown and read the manual.
It's a good manual and that's what it's there for.
John S.
stringkilla
89
Reply #5 on:
January 07, 2006, 08:57:32 AM »
John, that did not work. The manual does not address this issue. I've contacted Art for some expert advice in this matter. I've read the manual, and it's true there are many things there I do not understand. I thought that's what this and other forums where for?
rolexmechanic
26
Reply #6 on:
July 02, 2011, 12:07:49 PM »
http://designedplay.files.wordpress.com/2007/09/flash_keycodes.pdf
Print
Pages:
1
Go Up
« previous
next »
