Hello Guest it is November 13, 2026, 10:01:48 AM
Author Topic: Hotkey Keystrokes?  (Read 20188 times)
Hotkey Keystrokes?
« on: January 04, 2006, 08:07:12 PM »
I have another problem. I know I,m becoming a pest. I really need to know what keystroke's correspond to the number 33 and 34. These are the numbers in the hotkey boxes that control the Z axis jog. It seems in my panic I messed them up and now, I can't find them. I am in dire need. I need HELP.
Offline chad
  •  361 361
  • When the going gets weird, the weird turn pro.
Re: Hotkey Keystrokes?
« Reply #1 on: January 04, 2006, 10:04:04 PM »
The default Mach install will be, page-up, and page-down.  33 z++ 34 Z- -
chad
« Reply #2 on: January 05, 2006, 08:52:31 AM »
I guess I might ask this obvious question. Is that with the shift button??
« Reply #3 on: January 06, 2006, 07:47:01 AM »
Yes, but what keystrokes will make that happen? I'd like to get them back, but in the mean time I've allocated the numbers 1 & 4 for Z+, Z-, respectively. In the end I need to KNOW WHAT KEYSTROKES MAKE THE NUMBERS 33 & 34 end up in those boxes
Offline John S
  •  111 111
  • Nottingham England
« Reply #4 on: January 06, 2006, 08:48:45 AM »
High light the box needed like Z++ then whilst highlighted hit Page up and it will insert the number 33.
If the number 33 is alreday there then iy will use page up [ no shift]
Many of the questions you are asking are basic and you really do need to sitdown and read the manual.
It's a good manual and that's what it's there for.
John S.
« Reply #5 on: January 07, 2006, 08:57:32 AM »
John, that did not work. The manual does not address this issue. I've contacted Art for some expert advice in this matter. I've read the manual, and it's true there are many things there I do not understand. I thought that's what this and other forums where for?
