Hello Guest it is November 13, 2026, 07:59:34 PM
Author Topic: Help: My Step pin stay high all the time.  (Read 22968 times)
« on: July 03, 2009, 11:13:00 AM »
Hello,
My name is Amit, and I new to this softwere.
I build a simple CNC mechine. until now I build the X and Y axe, and i keep upgrade it all the time.
Until now I use turbocnc for windows, but this is very old and not easy to use softwere, so I decide to move to Mach3.
I start to config the softwere, but I have problem: my Step pin stay all the time high (or low if I config "Step low active")
For exmpale when I open the softwere, and enter JOG mode, in the begin the step pin is low, but when I did even one step, it stay high all the time.
Why this is happen? How I fix it?
Thenks a lot,
Amit Prigozin
Re: Help: My Step pin stay high all the time.
« Reply #1 on: July 03, 2009, 01:31:58 PM »
please attach your xml.
« Reply #2 on: July 03, 2009, 02:38:20 PM »
Thenks,
Here is my xml file
http://www.megaupload.com/?d=7VEZ1TT7
In this file I config only my X axe.
« Reply #3 on: July 03, 2009, 03:03:05 PM »
Turn on the Jog Control and see if that helps, middle of main screen at the bottom, says Jog On/Off
« Reply #4 on: July 03, 2009, 05:16:32 PM »
Nop...
Not help...
« Reply #5 on: July 03, 2009, 05:21:02 PM »
Do you have the drive/motor connected to the axis? If yes what happens?
« Reply #6 on: July 03, 2009, 05:28:08 PM »
I connect the wire to my controller which connected to 4 leds, each led repesent a coil of the step motor.
the leds keep changing all the time without stopping, they move in the right order (CW/CCW) but they dont stop when the command stop
« Reply #7 on: July 03, 2009, 05:37:14 PM »
Have you tried putting the LEDs direct to the paralle port on the computer?
Do the DROs keep moving in Mach after you release the keyboard key?
« Reply #8 on: July 03, 2009, 05:45:54 PM »
I cheack the volatge with FLUKE, and the pin stay high all the time, it is not the controller.
What is DROs? this is the number the represents the axe postion? becuse if yes-so they stop when I realse the key, if not-so I dont know what is DROs...
Thenks,
Amit Prigzoin
« Reply #9 on: July 03, 2009, 11:48:59 PM »
Yes that is what I was meaning, so if they Stop then Mach is acting like it should, afraid I have no idea what to suggest next except try with a motor hooked up rather than just LEDs.
