Hello Guest it is November 13, 2026, 07:01:06 PM
Author Topic: Mach3 does not go fast  (Read 14517 times)
Offline Robhi
  •  138 138
« on: June 28, 2009, 03:14:30 PM »
I tried the programme called scorpion that is attached with mach3 files, my mill machine 3 axes goes fast, I finish the file within 4 minutes.
But I tried to do very simple programme that was designed by mastercam x design, my mill goes too slowly, it moves nearly 3mm in 10 minutes.
Is there some thing wrong in my programme?
Robhi
Re: Mach3 does not go fast
« Reply #1 on: June 28, 2009, 05:13:06 PM »
What feedrates have you set in your programme and do you use metric or imperial units for Mach?
Offline Robhi
  •  138 138
« Reply #2 on: June 29, 2009, 02:02:15 PM »
I use metric system and my faderate is 100% I tried to use more than this but acceleration stays the same.
Offline Robhi
  •  138 138
« Reply #3 on: June 29, 2009, 02:48:29 PM »
Sorry,
 it is better that I attache the file itself
« Reply #4 on: June 29, 2009, 02:54:36 PM »
That has a G21 which makes it metric so thats correct but the feed is only 1.5mm/min so its going to crawl. You will have to specify a faster feed when doing your part in the CAM programme.
Offline Robhi
  •  138 138
« Reply #5 on: June 30, 2009, 02:31:22 PM »
Hello,
Thanks Hood, as well as all of you
I did as you said, you are right. I did so and everthing is fine...
Changing the feedrate in mastercam, that was the problem.
Thanks again
Robhi
