Hello Guest it is November 11, 2026, 11:14:36 PM
Author Topic: Adding a 4th axis to Proxxon MF70???  (Read 12543 times)
« on: June 26, 2009, 11:21:52 PM »
 Hi and sorry if this is already answered somewhere else here.
 Iam an untrained CNC user only self taught and doing ok with Mach3,Cut2d and my 3 axis cnc Proxxon MF70.
 I have been asked if I can make some helicopter parts which Iam sure I will need a 4th axis. I assume anyway.
 I understand I need the mechanical side of the 4th axis (Stepper,chuck,worm drive all in one)
Also I think I will need a tailstock which I have found to suit.
Iam upgrading the Hobbycnc board to 4 axis too.
 The part I am having trouble with is what software upgrades should I use to make it all work in harmony?
 Thanks in advance
 Jason
Re: Adding a 4th axis to Proxxon MF70???
« Reply #1 on: June 28, 2009, 06:52:14 PM »
No software upgrade needed as far as Mach is concerned, just enable the axis and set it up in motor tuning etc. From a CAM point of view you will need CAM that supports a 4th axis, either that or you will need to hand code.
« Reply #2 on: June 28, 2009, 07:24:02 PM »
 Thanks for the reply Hood,
 Can you recommend a cost effective CAM program to use for this?
 At the moment Iam only using Cut2d,Which works well for the parts I have been making up to now.
Thanks again.
Regards Jason
« Reply #3 on: June 29, 2009, 02:30:12 AM »
Not sure if there is such a thing :(
