Hello Guest it is November 22, 2026, 02:25:22 PM
Author Topic: Gibbs Cam  (Read 26710 times)
jkardias
Gibbs Cam
« on: August 20, 2006, 10:20:19 PM »
Is anyone using Gibbs Cam 2005?
What post processing file are you using?
I have just about every Post file for every CNC machine I just cant find one that produce a NC file that works flowlessly on the Mach3
Any Ideas which Post files is best to use so that I can get clean .NC files
Re: Gibbs Cam
« Reply #1 on: August 21, 2006, 06:11:22 AM »
I think Gibbs is the only one that can write up a post for Mach3.. I don't know this for sure but I think that is the case... I Also think it is 500.00 for a can post.
So call your dealer and see what they can do for you :(
Sorry
Brian
www.newfangledsolutions.com
www.machsupport.com
Will Slota
Re: Gibbs Cam
« Reply #2 on: August 30, 2006, 04:26:29 PM »
Mastercam has had a post processor that supports Mach 3 controlled CNC's for years.
jkardias
Re: Gibbs Cam
« Reply #3 on: September 05, 2006, 01:25:47 PM »
Thanks, would you happen to have the MasterCam Post File, Im in the process of developing a post process file for Gibbs cam, it would make thinging easier if i had a model to follow
Re: Gibbs Cam
« Reply #4 on: October 12, 2006, 05:35:29 AM »
"Mastercam has had a post processor that supports Mach 3 controlled CNC's for years."
Im searching for a post processor for Mach3! Could anybody tell me where I find it?
Thanks a lot,
Wolfram
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Gibbs Cam
« Reply #5 on: October 12, 2006, 04:16:48 PM »
jkardias
Re: Gibbs Cam
« Reply #6 on: November 07, 2006, 08:39:10 PM »
I finally got my Gibbs Post processor working nicely
hope you find it helpful
See atttached
Re: Gibbs Cam
« Reply #7 on: September 25, 2013, 04:49:45 PM »
it keeps shutting my Gibbs down any help
