G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: jkardias on August 20, 2006, 11:20:19 PM
Is anyone using Gibbs Cam 2005?
What post processing file are you using?
I have just about every Post file for every CNC machine I just cant find one that produce a NC file that works flowlessly on the Mach3
Any Ideas which Post files is best to use so that I can get clean .NC files
I think Gibbs is the only one that can write up a post for Mach3.. I don't know this for sure but I think that is the case... I Also think it is 500.00 for a can post.
So call your dealer and see what they can do for you :(
Sorry
Brian
Mastercam has had a post processor that supports Mach 3 controlled CNC's for years.
Thanks, would you happen to have the MasterCam Post File, Im in the process of developing a post process file for Gibbs cam, it would make thinging easier if i had a model to follow
"Mastercam has had a post processor that supports Mach 3 controlled CNC's for years."
Im searching for a post processor for Mach3! Could anybody tell me where I find it?
Thanks a lot,
Wolfram
Check this topic
http://www.machsupport.com/forum/index.php?topic=1306.msg7315#msg7315
I finally got my Gibbs Post processor working nicely
hope you find it helpful
See atttached
it keeps shutting my Gibbs down any help
