Hello Guest it is November 13, 2026, 08:07:03 PM
Author Topic: mapping joystick buttons  (Read 10937 times)
« on: June 24, 2009, 08:18:39 PM »
 Hello All
 I am setting up a logitech joystick/ gamepad and have most of the buttons assigned that I
want to  use, but I am trying to get use of the jog mode and jog cycle step off of the tab flyout
screen. I am using the keygrabber software and when I open the screen set with screen designer
I find only the oem codes and no keystrokes assigned to these buttons.
 Thanks Rick :)
Re: mapping joystick buttons
« Reply #1 on: June 25, 2009, 08:16:24 AM »
You can add hotkeys of your choice in Screen4, just make sure you choose something thats not already been used. Also be careful as the Jog keys may not work exactly as expected, it may start jogging and need an additional press to stop.
 One last thing is that to use HotKeys you need the button to actually be on the page you are viewing so you will either need screen 50 open or you will need to add the buttons top the pages yopu wish to be able to jog from.
