Hello Guest it is November 13, 2026, 08:00:38 PM
Author Topic: 4th Axis help  (Read 11535 times)
4th Axis help
« on: June 24, 2009, 11:40:34 AM »
Ok I looked and I cant find an answer,
I have a router table converted to do cylindrical engrraving.
My problem is feed rates are all screwed up.
When A is combined with X everything goes slow. When X is the only axis movining it is too fast.
I know angular feedrate is used when turnnig A and linear when moving X or Z.
How do I get A to feed in a linear fassion so it works with X????
I am using Artcam Pro and outputing Y2A on a post that was included with it.
I outputs A in degreees. and feed rate in the code does not change.
Please help I have a customer waiting for some parts
Re: 4th Axis help
« Reply #1 on: June 24, 2009, 12:42:50 PM »
FOUND IT
DISREGARD REQUEST FOR HELP
Re: 4th Axis help
« Reply #2 on: June 25, 2009, 06:41:08 AM »
Can you share what you found?
I'm working on a 4th axis also and I have not tackled the feed rate issue yet.
