Mach Discussion => General Mach Discussion => Topic started by: aji549 on June 24, 2009, 12:40:34 PM
Ok I looked and I cant find an answer,
I have a router table converted to do cylindrical engrraving.
My problem is feed rates are all screwed up.
When A is combined with X everything goes slow. When X is the only axis movining it is too fast.
I know angular feedrate is used when turnnig A and linear when moving X or Z.
How do I get A to feed in a linear fassion so it works with X????
I am using Artcam Pro and outputing Y2A on a post that was included with it.
I outputs A in degreees. and feed rate in the code does not change.
Please help I have a customer waiting for some parts
FOUND IT
DISREGARD REQUEST FOR HELP
Can you share what you found?
I'm working on a 4th axis also and I have not tackled the feed rate issue yet.
