Hello Guest it is November 19, 2026, 11:37:55 AM
Author Topic: Is there any other software than Lcam to convert DXF to g-code?  (Read 17306 times)
My friend got a cnc machine with PowerAutomation CNC controller,it got a plugin itself that was installed on Autocad,when u wanted to convert ur autocad file to G-code u had to right click on objects of ur dxf in autocad and select save as G-code...
my question is is there any other software ro plugin for autocad to convert 2D autocad drawings to Plasma g-code ?
thanx
Re: Is there any other software than Lcam to convert DXF to g-code?
« Reply #1 on: June 17, 2009, 06:47:20 AM »
There are a few free programs out that will provide Gcode out of Autocad. How good they are i do not know and also don't know if they address Plasma specifics . Never  really tried any of them.
Someone posted a program on this site which they wrote.
Search here, cnc zone, also the web.
« Reply #2 on: June 17, 2009, 10:32:29 AM »
I wrote one. I think the link is around here somewhere, but not sure where. It's also at CNC Zone in the AutoCAD forum there. PM me and I'll send you a link.
But it's not specifically for Plasma.
« Reply #3 on: June 17, 2009, 04:19:31 PM »
by the mean, i use Polylines to draw my drawing.like circles,and i have to put 2 lines,one for go inside the object and other to come from the object,but when trying to convert circles with Lazeycam, it seprates that lines from circle(remember i used to change object to polyline using PE command), here i attached the progress, can u help me?
and about the software i mean a simple little software to convert 2D dxf drawings to mach3 g-code...
i sent u a pm,
thanx...
« Reply #4 on: June 17, 2009, 07:05:49 PM »
Didn't get the PM, but here's a link to the macro.
http://home.comcast.net/~cncwoodworker/acad/downloads/ac2gcv043.zip
It'll only work in AutoCAD 2002 or newer. And, it should work with your example.
« Reply #5 on: June 18, 2009, 02:01:17 PM »
thanx,
but there's a problem, when i copy and nest myself,there are some free (rapid) lines that need m3 on each of drawing and m5 @ end of each, but ur converter puts one m3 on start and one m5 @ the end of the g-code file ...
« Reply #6 on: June 18, 2009, 06:51:02 PM »
Try using Mist or Flood, and then do a find and replace in a text editor to swap the M7's and M9's for M3's and M5's. Check the "Turn off coolant during rapids" box. That might get you close to what you want.
« Reply #7 on: June 29, 2009, 01:23:58 AM »
Try this one
http://mastor.no.sapo.pt/en/dark2d/dark2d.htm
It is for plasma especific
