G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: borbori on June 17, 2009, 02:38:18 AM
My friend got a cnc machine with PowerAutomation CNC controller,it got a plugin itself that was installed on Autocad,when u wanted to convert ur autocad file to G-code u had to right click on objects of ur dxf in autocad and select save as G-code...
my question is is there any other software ro plugin for autocad to convert 2D autocad drawings to Plasma g-code ?
thanx
There are a few free programs out that will provide Gcode out of Autocad. How good they are i do not know and also don't know if they address Plasma specifics . Never really tried any of them.
Someone posted a program on this site which they wrote.
Search here, cnc zone, also the web.
I wrote one. I think the link is around here somewhere, but not sure where. It's also at CNC Zone in the AutoCAD forum there. PM me and I'll send you a link.
But it's not specifically for Plasma.
by the mean, i use Polylines to draw my drawing.like circles,and i have to put 2 lines,one for go inside the object and other to come from the object,but when trying to convert circles with Lazeycam, it seprates that lines from circle(remember i used to change object to polyline using PE command), here i attached the progress, can u help me?
and about the software i mean a simple little software to convert 2D dxf drawings to mach3 g-code...
i sent u a pm,
thanx...
Didn't get the PM, but here's a link to the macro.
http://home.comcast.net/~cncwoodworker/acad/downloads/ac2gcv043.zip
It'll only work in AutoCAD 2002 or newer. And, it should work with your example.
thanx,
but there's a problem, when i copy and nest myself,there are some free (rapid) lines that need m3 on each of drawing and m5 @ end of each, but ur converter puts one m3 on start and one m5 @ the end of the g-code file ...
Try using Mist or Flood, and then do a find and replace in a text editor to swap the M7's and M9's for M3's and M5's. Check the "Turn off coolant during rapids" box. That might get you close to what you want.
Try this one
http://mastor.no.sapo.pt/en/dark2d/dark2d.htm
It is for plasma especific
