Hello Guest it is October 25, 2026, 02:44:58 AM
Author Topic: No motor movement. Need xml checked.  (Read 64517 times)
Re: No motor movement. Need xml checked.
« Reply #30 on: June 24, 2009, 08:54:52 AM »
Hollye
 Cant remember if it was mentioned or asked before but do you have a pulse frequency and Time In Int showing on the Diagnostics page?
« Reply #31 on: June 24, 2009, 09:01:21 AM »
Hood,
I am not sure. I ran the driver test and it showed 24335 but that may not mean anything. I was just going to lay down for a bit but let me go out and check real quick...
Hollye
« Reply #32 on: June 24, 2009, 09:07:40 AM »
Hood,
I am showing 25440 for pulse freq and INt is flucuating somewhere between 2 and 5. I did notice that I am showing an 'Idle' light green.
Hollye
« Reply #33 on: June 24, 2009, 09:12:35 AM »
Ok thats good regards frequ and Int, not sure on the Idle LED, dont use the standard screenset, can you post a screenshot of it.
« Reply #34 on: June 24, 2009, 09:33:26 AM »
Here it is Hood:
« Reply #35 on: June 24, 2009, 09:38:31 AM »
What screenset is that? just looked at the standard screen and I dont have that, what version of Mach is it, maybe mine is an older version as I have just updated via exe's for the last while.
« Reply #36 on: June 24, 2009, 09:39:34 AM »
Oh meant to ask, does the LED go out when you attempot to jog via keyboard?
« Reply #37 on: June 24, 2009, 09:46:40 AM »
Hood, I am running the original that I loaded when I got the machine, R1.84.000 the run and idle lights only come on when I run g-code.
I am off to lay down for a bit. I have guests coming over for a cookout this afternoon.
Let me know if you think of anything else. I have a sneaking feeling that these chips are bad. But, who knows?
Thanks for your help. I'll check back in an hour or so.
Hollye
« Reply #38 on: June 25, 2009, 01:42:17 PM »
Hood,
I got er goin'!!!!   :D It was those ICs. Popped them in and off it went! Thanks for all of your help. I might need some more when I upgrade to the full version which I will be doing soon. On that subject, the new version 3.84 (or whatever it is) has a pretty grainy user interface. What do you think. To me it doesn't look as pro as the 1.84. Am I doing something wrong? Or is it actually not as clean as the one I am running now?
Hollye
« Reply #39 on: June 25, 2009, 02:04:39 PM »
Thats great news :)
As for the interface, should be exactly the same, can you post a screenshot of both?
