Hello Guest it is October 20, 2026, 03:50:06 PM
Author Topic: Threading Wizard HELP -- Simple I think goes to wrong point.  (Read 17323 times)
OK, so I'm sure it's been covered but I can't find it.
I'm using the threading wizard in Mach 3.042 and when I go to run it, it move the carriage past the physical limts in the X6" and Z6" range. I have no idea why it's doing that and it crashes my carriage. The G code doesn't mention these coordinates so it must be some code. Please help. It does it for the first move.
Here's the code, oh I don't have any offsets set whatso ever I just zero the tool to the right coordinates. And I'm working in Inches. Oh and another thing the only werid setting I have is the IJ mode is set to absolute instead of incremental for my Dolphin CAM. Thanks.
G0 G40 G18 G80 G50 G90
G00 G53 X0.1 Z0.1
T202M6
G00  X1.795
G00 Z0.5
G00 X1.77
M03 S1000
M08
G76 X1.7316 Z-1 Q4 P0.03125 J0.001 L45 H0.01 I29 C0.025 B0.0001 T0
M9
M5
M30
Re: Threading Wizard HELP -- Simple I think goes to wrong point.
« Reply #1 on: June 12, 2009, 06:21:28 PM »
The second line is moving the X and Z axis to 0.1 in machine coordinates, do you home the machine?
« Reply #2 on: June 12, 2009, 06:23:36 PM »
No, I don't home it...OH, how can I get rid of that, I don't have limit switches on my machine?
« Reply #3 on: June 12, 2009, 06:28:13 PM »
I am afraid I dont use the standard lathe screen so not sure if there is a RefAll button on it or a means to set machine coords to zero, if there is then pressing that at an appropriate place would set it as machine zero.
Or if you edited that line out of the code it wouldnt go there, you could also edit the VB in the wizard so that it doesnt add that move, I think I did that in mine.
« Reply #4 on: June 12, 2009, 06:39:44 PM »
Just had a look at the VB, if you put the Tool number as zero then it shouldnt add that toolchange move, if you have the tooltable set however that wont be any good.
« Reply #5 on: June 12, 2009, 08:46:13 PM »
I have the same issue when generating files for my little 9x20, its just moving to a safe place to do a tool change if memory serves.  you just need to open the file in the editor and delete the g53 line  then save the file.
« Reply #6 on: June 12, 2009, 09:05:24 PM »
Thanks. I got it working, now the problem is understanding threading...so frustrating.
« Reply #7 on: June 12, 2009, 09:22:52 PM »
youll get the hang of it , like most canned cycles once you figure out what each of the variables are you'll just starting writing the code manualy. now if we could just get a couple of other common canned lathe cycles active ;)
« Reply #8 on: June 12, 2009, 10:53:31 PM »
Well the problem I'm having is the difference between using a full profile ER16 Insert or a partial profile ER16 insert. I'm doing a custom thread that's 1.77 OD for the bolt and 32 TPI, so I'm using 32 TPI specs. The problem is the bolt thread depth is .0192", but what's confusing is I asssume that's for a full profile cut. If I'm using a partial profile I'm supposed to leave a small flat on top, but that doesn't tell me how deep I should go.
