Hello Guest it is October 20, 2026, 03:02:26 PM
Author Topic: I need help with Mach3 setup.......  (Read 12237 times)
« on: June 11, 2009, 04:41:36 PM »
Hello,
I need some help to get the basic settings in Mach3. I have a Xylotex 3 axis driver board and Win XP SP3.
I need help with settings so I can get contact with my control cards, etc..
I hope there is someone who can help me with this... Thank's
I have these settings:
Port 1 Enabled
Kernel Speed 25000Hz
X axis step pin = 2  Dir pin = 3
Y axis step pin = 4  Dir pin = 5
Z axis step pin = 6  Dir pin = 7
Reset button blinks " Emergency Mode Active " nothing happens whether I press the button..?
Status: External EStop Requested.
How do I best be this problem ..?
Sorry for my English spelling ... I am from Sweden ....
Regards
Mikael
Sweden
Re: I need help with Mach3 setup.......
« Reply #1 on: June 11, 2009, 04:55:44 PM »
Go to Config menu then Ports and pins then Inputs, scroll down and change the active state of the E-Stop.
« Reply #2 on: June 13, 2009, 10:15:51 AM »
Thank's Hood.... The Reset button is OK now...
I need also help so I can get access to my step motors....
/Mikael
« Reply #3 on: June 13, 2009, 12:02:06 PM »
What is your problem with the motors?
