Hello Guest it is September 26, 2026, 02:23:19 PM
Author Topic: motors no go in mach 3...  (Read 32138 times)
« on: June 09, 2009, 11:45:02 PM »
Hi all,
I've got my cnc router working, it's my 2nd one, but I only used the first to get the
software working with my electronics & motors.. it was a terrible $100 design, and by then all the parts for the "good" one has arrived.:)
so I wired everything up,  took the setup that worked with the same electronics & motors, activated the 4th axis (x2), set the pins * ports, accel etc.
The test app that came with the board gets movement just fine, but mach 3 no movement. i go to the diagnostic screen, and
It shows no traffic over the port.
the port is the same as the tool that works is using.
Any ideas?
Eric-
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
Re: motors no go in mach 3...
« Reply #1 on: June 10, 2009, 02:09:49 AM »
I am not sure exactly where you are.
I take it Mach is installed in a computer, and works without any machine being connected to it. You can run programs etc and watch the software "cutting" your pattern. I take it the drivers are properly installed. If you are not at this point, then this should be your first proirity. Disregard any router, and get the Mach software running. Fill in the port and pins details (and activate them) as though you had a machine connected. If you can calculate your steps per unit for your new router motors, enter that. In other words do everything just as though your router was connected.
You do not say what connection there is to your router elctronics from your computer. I use the printer port, many now use a smooth stepper etc. If you are using the printer port, it is a simple matter to connect the cable, and test the various pins with a multi meter to see if signals are being sent. I must admit is you are not seeing anything on the diagnostics page, then you must probably have some settings incorrect - like enabling each axis, or entering the prot number as well as the pin.
You do not say what your drivers are (gecko etc? ) or what your motors are (200 step steppers ?) Are you using a breakout board ?
If you can set out where you are a bit more clearly, we will be able to help you with the problem.
« Reply #2 on: June 10, 2009, 07:23:57 PM »
Sorry, I was rushing to get it posted before bed :)
My Controller board is one of these,with the dynamo motors he sells.
http://www.stepperworld.com/fet3.htm#FET4target
IT connects over the printer port.
Here's the process I followed to get to my current position.(Sorry it's long winded, hopefully it'll bring us up to speed)
Built a baby $100 router, installed electronics & motors got them working and moving over parallel port with supplied testing software from electronics vendor (stepper world).
Installed mach 3, got it working and cutting virtually.
Purchased copy of Mach 3.
Had "no motor movement issue" (just like now), tried to diagnose with website help (from here), didn't' work.
One of the guys offered to call me and walk me through fixing it, and it started working after the first or second thing he tried (Thanks again Chip!).
I sat amazed at how quickly it was fixed, watching it twitch and whir.
It was now cutting, real shapes out of wood, but because I used cheap all thread and nuts, I had tons of problem getting it to run smoothly.
About this time the the parts started arriving for "the big router" that used real 5 start acme screws & anti backlash nuts, so I stopped working on the little one.
Started building "the Big one".
Alas thrust washers are totally on back order! Doh!
Winter is over before they arrive, no time to finish.
Frame with no motion installed sits in garage staring sullenly at me for months on end.
After a long hiatus, I finally got back and finished "the big router" that uses the same electronics and motors as the little one, except with a 4th axis used to double the x.
I got the electronics all wired up and got it working with the supplied testing software from www.stepperworld.com. I had motion on all 4 axis' in both directions.
Running all software on the same computer I had working from before.
I then loaded my old Mach 3 xml file, set the ports and pins for the 4th axis and the the limit switches and expected to be finished.
All Limit switched currently set to inactive to simplify debugging.
Started it carving the roadrunner with the z to high to cut, and got nothing... not a twitch.
The motors all work over the same parallel port using the simple testing software, so it's clearly something that I've failed to do properly in setting up Mach 3.
My reset has to be toggled each time I start mach 3 and I do this before loading a G-code file.
Mach 3 behaves as if it is cutting, I can see the movement on the position monitors and watch the cut path being followed.
My machine has crappy scores in Drivertest.exe but Chip said it just means the router will slow down and speed up with mouse movement and I can put off replacing the Box till later.
On the diagnosis screen I have numbers for pulse frequency, though they bounce all over the place 4- 5 digits.
I loaded the diagnostics, or trouble shooting screen, and watched the Parallel port Pins indicator 'lights' to see if Mach 3 thought it was sending data over the parallel port. No lights are flashing.
Mach 3 is set up on the same port that the StepperWorld.com software is functioning correctly over.(0x378)
Any help or hints are greatly appreciated.
Caladin-
« Last Edit: June 10, 2009, 09:25:07 PM by caladin »
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: June 11, 2009, 02:15:46 AM »
Hi, Eric
I sorta remember talking with you back in January, I still have your # and I'll try to give you a call if I see you on line hear.
In the mean time, Hear are a few thing's to try,
In port's & pin's set to Sherline 1/2 step Mode and try setting "All" the "Motor Output's",  "Low Active's" to "Checked", If that doesn't Help change them to "X"'ed and give it another Try.
On the Diagnostic Page, The "Led's" just under "Port 1 Pin Current State", Won't Show any Output's for Axis Movement's at All at this Time, So it's not a good indication of what's going On., ( It's caused So Many Issue's / Confusion over Time for "New User's" it's Scary).
Give it a Shot and let us know.
Thanks, Chip
« Reply #4 on: June 12, 2009, 12:20:05 AM »
Thanks for the help again Chip!
I've got motors turning.
After I hung up, i noticed that my 4th axis was not turning though.(it was behind me and i didn't see it just heard each axis move)
I RTFM and found the Slaving panel and set it to be slaved to my x axis,
as its supposed to. but when I Jogged the X and the 4 buttons no motion.
The pins are correct, and the rest is set up just like the other 3 axis.
The 4th axis moved under the test software.
I'll dig into the board manul and see if there is a separate disable/enable for the 4th axis,
but anyone has any other hints I'd love to hear them.
cal-
« Reply #5 on: June 13, 2009, 08:02:40 AM »
Cal,
What was the problem? I have a similar problem and wonder if something you did will help me.
Thanks Hollye
Offline Chip
  •  2,055 2,055
« Reply #6 on: June 13, 2009, 08:36:05 AM »
Hi, Hollye
His disable/enable pin 14 wasn't setup to Enable1 Output in Mach.
Chip
« Reply #7 on: June 13, 2009, 10:24:05 AM »
Oh, OK Thank you.
« Reply #8 on: June 13, 2009, 01:04:13 PM »
Yet 14 was set to enable.
If you're having a similar issue, chip recommended to me to start by turning 1/2 pulse mode on, and leave it on till things are working before you try it with it off.
some boards need more time to sense the pulse and Sherline mode makes it go slower.
If you want to see how I set these settings in Mach 3, go here:
(copy and paste the link, the site is not setting it up correctly to just click)
http://mycncprojects.wetpaint.com/page/Motion!+it%27s+(sorta)+alive!
Where I'm keeping track of progress lately. It's not fancy it's most there so i can keep track of what I've changed
So that if i have these troubles again, kind of like a diary.
It includes pics of the screen and where to set the settings I've mentioned so far.
Re my slaved axis issues, I checked the manual, as I remembered (2pp) there was only a master enable, which is on (now)
and I've set the slaving, so I'm still fiddling with it hoping to get the A axis working and slaved to the X axis.
I turned it off Sherline 1/2 step mode and everything (else)  seemed to run fine.
« Last Edit: June 13, 2009, 01:10:38 PM by caladin »
« Reply #9 on: June 13, 2009, 04:16:09 PM »
Cal,
Thank you for the info. I only have three axis and I found a reference on one of the other threads that indicated that uninstalling the parallel port and letting Windows reinstall it many times solves the problem. I am going to give this a try this evening if I get time and, if this does not work, I will try the enable and Sherline toggle. Somehow I have to get this thing going.
Thank you for your help. I will let you know how it goes.
Hollye
