Hello
Guest
it is
October 16, 2026, 12:26:24 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
M9 doesnt turn off coolant
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: M9 doesnt turn off coolant (Read 13636 times)
panaceabeachbum
338
on:
June 05, 2009, 09:13:41 PM »
I can turn on coolant with m8 as expected but cannot turn it off via m9, also does not turn off when m30 is called out either. Should there be an m8 and m9 file in macros? Possibly some setting I have missed?
www.thompsonmachine.net
HimyKabibble
1,687
Re: M9 doesnt turn off coolant
Reply #1 on:
June 05, 2009, 10:24:28 PM »
That's pretty odd.... No macros required. Sounds like maybe your install got whacked?
vmax549
Reply #2 on:
June 05, 2009, 10:28:35 PM »
For the M30 check the config page down to the prgend /m30 section check turn off all outputs.
As to the M9 HUM, does the coolant turn OFF from the main page button?
Just a thought (;-) TP
Carnoustie, Scotland
Reply #3 on:
June 06, 2009, 10:53:47 AM »
please attach your xml.
panaceabeachbum
338
Reply #4 on:
June 06, 2009, 12:33:51 PM »
no I cannot turn the coolant off from the main page , once on it just continues to run until mach is shut down and restarted or you unplug the pump. will reload and see what happens, m9 worked once then hasnt since
Last Edit: June 06, 2009, 06:16:41 PM by panaceabeachbum
Print
Pages:
1
Go Up
« previous
next »
