Hello Guest it is October 15, 2026, 10:31:24 PM
Author Topic: M9 doesnt turn off coolant  (Read 13630 times)
« on: June 05, 2009, 09:13:41 PM »
I can turn on coolant with m8 as expected but cannot turn it off via m9, also does not turn off when m30 is called out either.  Should there be an m8 and m9 file in macros? Possibly some setting I have missed?
Re: M9 doesnt turn off coolant
« Reply #1 on: June 05, 2009, 10:24:28 PM »
That's pretty odd....  No macros required.  Sounds like maybe your install got whacked?
vmax549
« Reply #2 on: June 05, 2009, 10:28:35 PM »
For the M30 check the config page down to the prgend /m30 section check     turn off all outputs.
As to the M9 HUM, does the coolant turn OFF from the main page button?
Just a thought (;-) TP
« Reply #3 on: June 06, 2009, 10:53:47 AM »
please attach your xml.
« Reply #4 on: June 06, 2009, 12:33:51 PM »
no I cannot turn the coolant off from the main page , once on it just continues to run until mach is shut down and restarted or you unplug the pump. will reload and see what happens, m9 worked once then hasnt since
« Last Edit: June 06, 2009, 06:16:41 PM by panaceabeachbum »
