Hello Guest it is October 16, 2026, 12:26:08 AM
Author Topic: Initial feed rate  (Read 11775 times)
Initial feed rate
« on: August 16, 2006, 02:04:37 AM »
Hi, is it possible to change the settings for the feed rate at the startup the program?
I think it's 6 units now and when using millimeter as unit my jogging is very slow.
Roger
Re: Initial feed rate
« Reply #1 on: August 16, 2006, 05:47:42 AM »
Feed and Jog are not the same :(
Here is how you can change each one :)
To set the feed put an F(whatever you like) into the Init String on the Config Settings page
and to change the slow jog rate press Tab and you will get a fly out with all the jog settings.. there is a slow jog %, change that till you are happy
www.newfangledsolutions.com
www.machsupport.com
« Reply #2 on: August 28, 2006, 04:20:54 PM »
Hi Brian,
Could you, please, help me to undesratnd where I find "init String" and "Configuration Settings page"?
I want to change the initial Feed rate.
Thank you,
Zoltan
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: August 28, 2006, 07:06:53 PM »
Hi, Zoltan
This is for Mach3D1.90.07? and on.
Top left of screen click on Config, select General Config...., find Startup Modals, Put a check in Use Init String on ALL "Resets Box", then Add your F-speed in window just below, after the G80, then click OK.
Hope this helps, Chip
