Hello Guest it is November 12, 2026, 07:41:17 AM
Author Topic: y axis  (Read 46450 times)
Offline PCH
  •  80 80
y axis
« on: June 03, 2009, 12:49:43 PM »
After several hours with Bobcad support it was determined that the code is valid.
What is happening is the cuts in the y axis are not consistant with the drawing or the code.
For some reason the rectangular shapes are not lining up with repect to the y axis.  They are offesting around an 1/8" or so from each other even though in the drawing and code they are aligned perfectly.
Is there something in the config. menus that need changed?
Pat >:(
Re: y axis
« Reply #1 on: June 03, 2009, 12:58:49 PM »
does the toolpath show correctly?
Can you attach the code  and also your xml please
Offline PCH
  •  80 80
Re: y axis
« Reply #2 on: June 03, 2009, 01:38:51 PM »
Forgot to tell you that my toolpath does show correctly.
Did you get the attachments okay?
Re: y axis
« Reply #3 on: June 03, 2009, 02:04:46 PM »
No, never got any attachments
Offline PCH
  •  80 80
Re: y axis
« Reply #4 on: June 03, 2009, 02:30:21 PM »
O00100 ( PROGRAM NUMBER)
( BEGIN PREDATOR NC HEADER)
( MACH_FILE=3AXVMILL.MCH)
( MTOOL T1 S1 D0.0625 H5. DIAM_OFFSET 1 = 0.0313)
( MTOOL T2 S1 D0.0625 H5. DIAM_OFFSET 2 = 0.0313)
( SBOX X10. Y1. Z-1. L2.4361 W14.2095 H1.)
( END PREDATOR NC HEADER)
( PROGRAM NAME - MACVASESQMOROSCO.NC)
( POST -  ACU-RITE MILLPWR 3AXIS)
( DATE - WED. 06/03/2009)
( TIME - 02:38PM)
N01 G00 G17 G20 G40 G49 G80 G90 G94
( FIRST CUT - FIRST TOOL)
(JOB 1  CONTOUR)
(FEATURE PROFILE)
N02 T1 M06
N03 G00 G90 G54 X11.033 Y3.6646 Z0.1 S10000 M03
N04 G00 X11.033 Y3.6646 Z0.1 M08
N05 G01 X11.033 Y3.6646 Z-0.125 F20.
N06 G01 X11.033 Y3.6061 Z-0.125 F40.
N07 G01 X10.9159 Y3.6061 Z-0.125 F40.
N08 G01 X10.9159 Y3.7232 Z-0.125 F40.
N09 G01 X11.033 Y3.7232 Z-0.125 F40.
N10 G01 X11.033 Y3.6646 Z-0.125 F40.
N11 G00 X11.033 Y3.6646 Z0.1
N12 G00 X11.4031 Y3.6646 Z0.1
N13 G01 X11.4031 Y3.6646 Z-0.125 F20.
N14 G01 X11.4031 Y3.7232 Z-0.125 F40.
N15 G01 X11.5202 Y3.7232 Z-0.125 F40.
N16 G01 X11.5202 Y3.6061 Z-0.125 F40.
N17 G01 X11.4031 Y3.6061 Z-0.125 F40.
N18 G01 X11.4031 Y3.6646 Z-0.125 F40.
N19 G00 X11.4031 Y3.6646 Z0.1
N20 G00 X11.4031 Y4.1518 Z0.1
N21 G01 X11.4031 Y4.1518 Z-0.125 F20.
N22 G01 X11.4031 Y4.2104 Z-0.125 F40.
N23 G01 X11.5202 Y4.2104 Z-0.125 F40.
N24 G01 X11.5202 Y4.0933 Z-0.125 F40.
N25 G01 X11.4031 Y4.0933 Z-0.125 F40.
N26 G01 X11.4031 Y4.1518 Z-0.125 F40.
N27 G00 X11.4031 Y4.1518 Z0.1
N28 G00 X11.033 Y4.1518 Z0.1
N29 G01 X11.033 Y4.1518 Z-0.125 F20.
N30 G01 X11.033 Y4.0933 Z-0.125 F40.
N31 G01 X10.9159 Y4.0933 Z-0.125 F40.
N32 G01 X10.9159 Y4.2104 Z-0.125 F40.
N33 G01 X11.033 Y4.2104 Z-0.125 F40.
N34 G01 X11.033 Y4.1518 Z-0.125 F40.
N35 G00 X11.033 Y4.1518 Z0.1
N36 G00 X10.5458 Y4.3955 Z0.1
N37 G01 X10.5458 Y4.3955 Z-0.125 F20.
N38 G01 X10.5458 Y3.6061 Z-0.125 F40.
N39 G01 X10.4287 Y3.6061 Z-0.125 F40.
N40 G01 X10.4287 Y5.1848 Z-0.125 F40.
N41 G01 X10.5458 Y5.1848 Z-0.125 F40.
N42 G01 X10.5458 Y4.3955 Z-0.125 F40.
N43 G00 X10.5458 Y4.3955 Z0.1
N44 G00 X10.9744 Y4.6976 Z0.1
N45 G01 X10.9744 Y4.6976 Z-0.125 F20.
N46 G01 X11.033 Y4.6976 Z-0.125 F40.
N47 G01 X11.033 Y4.5805 Z-0.125 F40.
N48 G01 X10.9159 Y4.5805 Z-0.125 F40.
N49 G01 X10.9159 Y4.6976 Z-0.125 F40.
N50 G01 X10.9744 Y4.6976 Z-0.125 F40.
N51 G00 X10.9744 Y4.6976 Z0.1
N52 G00 X11.033 Y5.1263 Z0.1
N53 G01 X11.033 Y5.1263 Z-0.125 F20.
N54 G01 X11.033 Y5.0677 Z-0.125 F40.
N55 G01 X10.9159 Y5.0677 Z-0.125 F40.
N56 G01 X10.9159 Y5.1848 Z-0.125 F40.
N57 G01 X11.033 Y5.1848 Z-0.125 F40.
N58 G01 X11.033 Y5.1263 Z-0.125 F40.
N59 G00 X11.033 Y5.1263 Z0.1
N60 G00 X11.4031 Y5.1263 Z0.1
N61 G01 X11.4031 Y5.1263 Z-0.125 F20.
N62 G01 X11.4031 Y5.1848 Z-0.125 F40.
N63 G01 X11.5202 Y5.1848 Z-0.125 F40.
N64 G01 X11.5202 Y5.0677 Z-0.125 F40.
N65 G01 X11.4031 Y5.0677 Z-0.125 F40.
N66 G01 X11.4031 Y5.1263 Z-0.125 F40.
N67 G00 X11.4031 Y5.1263 Z0.1
N68 G00 X11.4617 Y4.6976 Z0.1
N69 G01 X11.4617 Y4.6976 Z-0.125 F20.
N70 G01 X11.5202 Y4.6976 Z-0.125 F40.
N71 G01 X11.5202 Y4.5805 Z-0.125 F40.
N72 G01 X11.4031 Y4.5805 Z-0.125 F40.
N73 G01 X11.4031 Y4.6976 Z-0.125 F40.
N74 G01 X11.4617 Y4.6976 Z-0.125 F40.
N75 G00 X11.4617 Y4.6976 Z0.1
N76 G00 X12.0074 Y4.3955 Z0.1
N77 G01 X12.0074 Y4.3955 Z-0.125 F20.
N78 G01 X12.0074 Y3.6061 Z-0.125 F40.
N79 G01 X11.8903 Y3.6061 Z-0.125 F40.
N80 G01 X11.8903 Y5.1848 Z-0.125 F40.
N81 G01 X12.0074 Y5.1848 Z-0.125 F40.
N82 G01 X12.0074 Y4.3955 Z-0.125 F40.
N83 G00 X12.0074 Y4.3955 Z0.1
N84 G00 X12.0074 Y10.1679 Z0.1
N85 G01 X12.0074 Y10.1679 Z-0.125 F20.
N86 G01 X12.0074 Y5.555 Z-0.125 F40.
N87 G01 X11.8903 Y5.555 Z-0.125 F40.
N88 G01 X11.8903 Y14.7808 Z-0.125 F40.
N89 G01 X12.0074 Y14.7808 Z-0.125 F40.
N90 G01 X12.0074 Y10.1679 Z-0.125 F40.
N91 G00 X12.0074 Y10.1679 Z0.1
N92 G00 X11.5202 Y10.1679 Z0.1
N93 G01 X11.5202 Y10.1679 Z-0.125 F20.
N94 G01 X11.5202 Y5.555 Z-0.125 F40.
N95 G01 X11.4031 Y5.555 Z-0.125 F40.
N96 G01 X11.4031 Y14.7808 Z-0.125 F40.
N97 G01 X11.5202 Y14.7808 Z-0.125 F40.
N98 G01 X11.5202 Y10.1679 Z-0.125 F40.
N99 G00 X11.5202 Y10.1679 Z0.1
N100 G00 X11.033 Y10.1679 Z0.1
N101 G01 X11.033 Y10.1679 Z-0.125 F20.
N102 G01 X11.033 Y5.555 Z-0.125 F40.
N103 G01 X10.9159 Y5.555 Z-0.125 F40.
N104 G01 X10.9159 Y14.7808 Z-0.125 F40.
N105 G01 X11.033 Y14.7808 Z-0.125 F40.
N106 G01 X11.033 Y10.1679 Z-0.125 F40.
N107 G00 X11.033 Y10.1679 Z0.1
N108 G00 X10.5458 Y10.1679 Z0.1
N109 G01 X10.5458 Y10.1679 Z-0.125 F20.
N110 G01 X10.5458 Y5.555 Z-0.125 F40.
N111 G01 X10.4287 Y5.555 Z-0.125 F40.
N112 G01 X10.4287 Y14.7808 Z-0.125 F40.
N113 G01 X10.5458 Y14.7808 Z-0.125 F40.
N114 G01 X10.5458 Y10.1679 Z-0.125 F40.
N115 G00 X10.5458 Y10.1679 Z0.1
( NEXT CUT - SAME TOOL)
(JOB 3  POCKET)
(FEATURE POCKET)
N116 G00 G90 G54 X10.9244 Y2.6631 S10000
N117 G01 X10.9244 Y2.6631 Z-0.032 F20.
N118 G03 X10.9458 Y2.6092 Z-0.032 I0.0214 J-0.0227 F30.
N119 G01 X11.4908 Y2.6092 Z-0.032 F30.
N120 G03 X11.5123 Y2.6631 Z-0.032 I0. J0.0313 F30.
N121 G03 X10.9244 Y2.6631 Z-0.032 I-0.294 J-0.3115 F30.
N122 G01 X10.9199 Y2.6679 Z-0.032 F30.
N123 G03 X10.808 Y2.4956 Z-0.032 I0.2985 J-0.3162 F30.
N124 G01 X10.8142 Y2.4934 Z-0.032 F30.
N125 G03 X10.8437 Y2.4519 Z-0.032 I0.0295 J-0.0103 F30.
N126 G01 X11.593 Y2.4519 Z-0.032 F30.
N127 G03 X11.6225 Y2.4934 Z-0.032 I0. J0.0313 F30.
N128 G03 X11.5913 Y2.5623 Z-0.032 I-0.4041 J-0.1418 F30.
N129 G03 X11.564 Y2.5782 Z-0.032 I-0.0272 J-0.0154 F30.
N130 G01 X10.8726 Y2.5782 Z-0.032 F30.
N131 G03 X10.8454 Y2.5623 Z-0.032 I0. J-0.0313 F30.
N132 G03 X10.8142 Y2.4934 Z-0.032 I0.3729 J-0.2106 F30.
N133 G01 X10.808 Y2.4956 Z-0.032 F30.
N134 G03 X10.8011 Y2.4743 Z-0.032 I0.4103 J-0.144 F30.
N135 G02 X10.7711 Y2.4519 Z-0.032 I-0.03 J0.0088 F30.
N136 G01 X10.6358 Y2.4519 Z-0.032 F30.
N137 G02 X10.6053 Y2.49 Z-0.032 I0. J0.0313 F30.
N138 G03 X10.6358 Y2.4519 Z-0.032 I0.0305 J-0.0069 F30.
N139 G01 X10.7711 Y2.4519 Z-0.032 F30.
N140 G03 X10.8011 Y2.4743 Z-0.032 I0. J0.0313 F30.
N141 G02 X10.808 Y2.4956 Z-0.032 I0.4172 J-0.1226 F30.
N142 G02 X10.9199 Y2.6679 Z-0.032 I0.4103 J-0.144 F30.
N143 G02 X11.1806 Y2.7849 Z-0.032 I0.2985 J-0.3162 F30.
N144 G03 X11.2091 Y2.816 Z-0.032 I-0.0027 J0.0311 F30.
N145 G01 X11.2091 Y2.9475 Z-0.032 F30.
N146 G03 X11.1758 Y2.9787 Z-0.032 I-0.0313 J0. F30.
N147 G03 X10.6053 Y2.49 Z-0.032 I0.0425 J-0.627 F30.
N148 G03 X10.6022 Y2.4769 Z-0.032 I0.613 J-0.1383 F30.
N149 G02 X10.5716 Y2.4519 Z-0.032 I-0.0306 J0.0062 F30.
N150 G01 X10.5078 Y2.4519 Z-0.032 F30.
N151 G02 X10.4766 Y2.4831 Z-0.032 I0. J0.0313 F30.
N152 G01 X10.4766 Y3.0431 Z-0.032 F30.
N153 G01 X10.4766 Y2.4831 Z-0.032 F30.
N154 G03 X10.5078 Y2.4519 Z-0.032 I0.0313 J0. F30.
N155 G01 X10.5716 Y2.4519 Z-0.032 F30.
N156 G03 X10.6022 Y2.4769 Z-0.032 I0. J0.0313 F30.
N157 G02 X10.6051 Y2.49 Z-0.032 I0.6161 J-0.1252 F30.
N158 G02 X10.6251 Y2.5598 Z-0.032 I0.6133 J-0.1384 F30.
N159 G02 X11.1798 Y2.9792 Z-0.032 I0.5932 J-0.2081 F30.
N160 G03 X11.2091 Y3.0104 Z-0.032 I-0.0019 J0.0312 F30.
N161 G01 X11.2091 Y3.0431 Z-0.032 F30.
N162 G03 X11.1779 Y3.0743 Z-0.032 I-0.0313 J0. F30.
N163 G01 X10.5078 Y3.0743 Z-0.032 F30.
N164 G03 X10.4766 Y3.0431 Z-0.032 I0. J-0.0313 F30.
N165 G01 X10.4756 Y3.0753 Z-0.032 F30.
N166 G01 X10.9244 Y3.0753 Z-0.032 F30.
N167 G01 X11.1758 Y3.0753 Z-0.032 F30.
N168 G01 X11.2587 Y3.0753 Z-0.032 F30.
N169 G03 X11.2275 Y3.0431 Z-0.032 I0. J-0.0322 F30.
N170 G01 X11.2275 Y3.0104 Z-0.032 F30.
N171 G03 X11.2568 Y2.9792 Z-0.032 I0.0313 J0. F30.
N172 G02 X11.2609 Y2.9789 Z-0.032 I-0.0385 J-0.6275 F30.
N173 G03 X11.2275 Y2.9475 Z-0.032 I-0.0021 J-0.0314 F30.
N174 G01 X11.2275 Y2.816 Z-0.032 F30.
N175 G03 X11.256 Y2.7849 Z-0.032 I0.0313 J0. F30.
N176 G02 X11.6355 Y2.4743 Z-0.032 I-0.0377 J-0.4332 F30.
N177 G03 X11.6655 Y2.4519 Z-0.032 I0.03 J0.0088 F30.
N178 G01 X11.8009 Y2.4519 Z-0.032 F30.
N179 G03 X11.8314 Y2.49 Z-0.032 I0. J0.0313 F30.
N180 G03 X11.2609 Y2.9787 Z-0.032 I-0.613 J-0.1383 F30.
N181 G03 X11.2568 Y2.9792 Z-0.032 I-0.0425 J-0.627 F30.
N182 G02 X11.2275 Y3.0104 Z-0.032 I0.0019 J0.0312 F30.
N183 G01 X11.2275 Y3.0431 Z-0.032 F30.
N184 G02 X11.2587 Y3.0743 Z-0.032 I0.0313 J0. F30.
N185 G03 X11.2275 Y3.0431 Z-0.032 I0. J-0.0313 F30.
N186 G01 X11.2275 Y3.0104 Z-0.032 F30.
N187 G03 X11.2568 Y2.9792 Z-0.032 I0.0313 J0. F30.
N188 G02 X11.2609 Y2.9789 Z-0.032 I-0.0385 J-0.6275 F30.
N189 G02 X11.8344 Y2.4769 Z-0.032 I-0.0426 J-0.6272 F30.
N190 G03 X11.865 Y2.4519 Z-0.032 I0.0306 J0.0062 F30.
N191 G01 X11.9288 Y2.4519 Z-0.032 F30.
N192 G03 X11.9601 Y2.4831 Z-0.032 I0. J0.0313 F30.
N193 G01 X11.9601 Y3.0431 Z-0.032 F30.
N194 G03 X11.9288 Y3.0743 Z-0.032 I-0.0313 J0. F30.
N195 G01 X11.2587 Y3.0743 Z-0.032 F30.
N196 G01 X11.2609 Y3.0753 Z-0.032 F30.
N197 G01 X11.9611 Y3.0753 Z-0.032 F30.
N198 G01 X11.9611 Y2.4841 Z-0.032 F30.
N199 G03 X11.9923 Y2.4529 Z-0.032 I0.0313 J0. F30.
N200 G01 X12.1049 Y2.4529 Z-0.032 F30.
N201 G01 X12.1049 Y2.4196 Z-0.032 F30.
N202 G03 X12.0726 Y2.4509 Z-0.032 I-0.0322 J0. F30.
N203 G01 X10.358 Y2.4509 Z-0.032 F30.
N204 G03 X10.3268 Y2.4196 Z-0.032 I0. J-0.0313 F30.
N205 G01 X10.3268 Y2.2837 Z-0.032 F30.
N206 G03 X10.358 Y2.2525 Z-0.032 I0.0313 J0. F30.
N207 G01 X12.0726 Y2.2525 Z-0.032 F30.
N208 G03 X12.1039 Y2.2837 Z-0.032 I0. J0.0313 F30.
N209 G01 X12.1039 Y2.4196 Z-0.032 F30.
N210 G01 X12.1049 Y2.2505 Z-0.032 F30.
N211 G01 X11.9923 Y2.2505 Z-0.032 F30.
N212 G03 X11.9611 Y2.2192 Z-0.032 I0. J-0.0313 F30.
N213 G01 X11.9611 Y2.2099 Z-0.032 F30.
N214 G01 X11.9611 Y1.6602 Z-0.032 F30.
N215 G01 X11.9611 Y1.628 Z-0.032 F30.
N216 G01 X11.5123 Y1.628 Z-0.032 F30.
N217 G01 X11.2609 Y1.628 Z-0.032 F30.
N218 G01 X11.1779 Y1.628 Z-0.032 F30.
N219 G03 X11.2091 Y1.6602 Z-0.032 I0. J0.0323 F30.
N220 G01 X11.2091 Y1.693 Z-0.032 F30.
N221 G03 X11.1798 Y1.7242 Z-0.032 I-0.0313 J0. F30.
N222 G02 X11.1758 Y1.7244 Z-0.032 I0.0385 J0.6275 F30.
N223 G03 X11.2091 Y1.7558 Z-0.032 I0.0021 J0.0314 F30.
N224 G01 X11.2091 Y1.8873 Z-0.032 F30.
N225 G03 X11.1806 Y1.9184 Z-0.032 I-0.0313 J0. F30.
N226 G02 X10.8011 Y2.229 Z-0.032 I0.0377 J0.4332 F30.
N227 G03 X10.7711 Y2.2515 Z-0.032 I-0.03 J-0.0088 F30.
N228 G01 X10.6358 Y2.2515 Z-0.032 F30.
N229 G03 X10.6053 Y2.2133 Z-0.032 I0. J-0.0313 F30.
N230 G03 X11.1758 Y1.7247 Z-0.032 I0.613 J0.1383 F30.
N231 G03 X11.1798 Y1.7242 Z-0.032 I0.0425 J0.627 F30.
N232 G02 X11.2091 Y1.693 Z-0.032 I-0.0019 J-0.0312 F30.
N233 G01 X11.2091 Y1.6602 Z-0.032 F30.
N234 G02 X11.1779 Y1.629 Z-0.032 I-0.0313 J0. F30.
N235 G03 X11.2091 Y1.6602 Z-0.032 I0. J0.0313 F30.
N236 G01 X11.2091 Y1.693 Z-0.032 F30.
N237 G03 X11.1798 Y1.7242 Z-0.032 I-0.0313 J0. F30.
N238 G02 X11.1758 Y1.7244 Z-0.032 I0.0385 J0.6275 F30.
N239 G02 X10.6022 Y2.2264 Z-0.032 I0.0426 J0.6272 F30.
N240 G03 X10.5716 Y2.2515 Z-0.032 I-0.0306 J-0.0062 F30.
N241 G01 X10.5078 Y2.2515 Z-0.032 F30.
N242 G03 X10.4766 Y2.2202 Z-0.032 I0. J-0.0313 F30.
N243 G01 X10.4766 Y1.6602 Z-0.032 F30.
N244 G03 X10.5078 Y1.629 Z-0.032 I0.0313 J0. F30.
N245 G01 X11.1779 Y1.629 Z-0.032 F30.
N246 G01 X11.2609 Y1.628 Z-0.032 F30.
N247 G01 X11.5123 Y1.628 Z-0.032 F30.
N248 G01 X11.9611 Y1.628 Z-0.032 F30.
N249 G01 X11.9611 Y1.6602 Z-0.032 F30.
N250 G01 X11.9601 Y2.2202 Z-0.032 F30.
N251 G03 X11.9288 Y2.2515 Z-0.032 I-0.0313 J0. F30.
N252 G01 X11.865 Y2.2515 Z-0.032 F30.
N253 G03 X11.8344 Y2.2264 Z-0.032 I0. J-0.0313 F30.
N254 G02 X11.8316 Y2.2133 Z-0.032 I-0.6161 J0.1252 F30.
N255 G03 X11.8009 Y2.2515 Z-0.032 I-0.0307 J0.0069 F30.
N256 G01 X11.6655 Y2.2515 Z-0.032 F30.
N257 G03 X11.6355 Y2.229 Z-0.032 I0. J-0.0313 F30.
N258 G02 X11.6286 Y2.2077 Z-0.032 I-0.4172 J0.1226 F30.
N259 G02 X11.5168 Y2.0354 Z-0.032 I-0.4103 J0.144 F30.
N260 G01 X11.5123 Y2.0402 Z-0.032 F30.
N261 G03 X11.4908 Y2.0942 Z-0.032 I-0.0214 J0.0227 F30.
N262 G01 X10.9458 Y2.0942 Z-0.032 F30.
N263 G03 X10.9244 Y2.0402 Z-0.032 I0. J-0.0313 F30.
N264 G03 X11.5123 Y2.0402 Z-0.032 I0.294 J0.3115 F30.
N265 G01 X11.5168 Y2.0354 Z-0.032 F30.
N266 G03 X11.6286 Y2.2077 Z-0.032 I-0.2985 J0.3162 F30.
N267 G01 X11.6225 Y2.2099 Z-0.032 F30.
N268 G03 X11.593 Y2.2515 Z-0.032 I-0.0295 J0.0103 F30.
N269 G01 X10.8437 Y2.2515 Z-0.032 F30.
N270 G03 X10.8142 Y2.2099 Z-0.032 I0. J-0.0313 F30.
N271 G03 X10.8454 Y2.141 Z-0.032 I0.4041 J0.1418 F30.
N272 G03 X10.8726 Y2.1252 Z-0.032 I0.0272 J0.0154 F30.
N273 G01 X11.564 Y2.1252 Z-0.032 F30.
N274 G03 X11.5913 Y2.141 Z-0.032 I0. J0.0313 F30.
N275 G03 X11.6225 Y2.2099 Z-0.032 I-0.3729 J0.2106 F30.
N276 G01 X11.6286 Y2.2077 Z-0.032 F30.
N277 G03 X11.6355 Y2.229 Z-0.032 I-0.4103 J0.144 F30.
N278 G02 X11.6655 Y2.2515 Z-0.032 I0.03 J-0.0088 F30.
N279 G01 X11.8009 Y2.2515 Z-0.032 F30.
N280 G02 X11.8314 Y2.2133 Z-0.032 I0. J-0.0313 F30.
N281 G03 X11.8009 Y2.2515 Z-0.032 I-0.0305 J0.0069 F30.
N282 G01 X11.6655 Y2.2515 Z-0.032 F30.
N283 G03 X11.6355 Y2.229 Z-0.032 I0. J-0.0313 F30.
N284 G02 X11.6286 Y2.2077 Z-0.032 I-0.4172 J0.1226 F30.
N285 G02 X11.5168 Y2.0354 Z-0.032 I-0.4103 J0.144 F30.
N286 G02 X11.256 Y1.9184 Z-0.032 I-0.2985 J0.3162 F30.
N287 G03 X11.2275 Y1.8873 Z-0.032 I0.0027 J-0.0311 F30.
N288 G01 X11.2275 Y1.7558 Z-0.032 F30.
N289 G03 X11.2609 Y1.7247 Z-0.032 I0.0313 J0. F30.
N290 G03 X11.8314 Y2.2133 Z-0.032 I-0.0425 J0.627 F30.
N291 G03 X11.8344 Y2.2264 Z-0.032 I-0.613 J0.1383 F30.
N292 G02 X11.865 Y2.2515 Z-0.032 I0.0306 J-0.0062 F30.
N293 G01 X11.9288 Y2.2515 Z-0.032 F30.
N294 G02 X11.9601 Y2.2202 Z-0.032 I0. J-0.0313 F30.
N295 G01 X11.9601 Y1.6602 Z-0.032 F30.
N296 G01 X11.9601 Y2.2202 Z-0.032 F30.
N297 G03 X11.9288 Y2.2515 Z-0.032 I-0.0313 J0. F30.
N298 G01 X11.865 Y2.2515 Z-0.032 F30.
N299 G03 X11.8344 Y2.2264 Z-0.032 I0. J-0.0313 F30.
N300 G02 X11.8316 Y2.2133 Z-0.032 I-0.6161 J0.1252 F30.
N301 G02 X11.8116 Y2.1435 Z-0.032 I-0.6133 J0.1384 F30.
N302 G02 X11.2568 Y1.7242 Z-0.032 I-0.5932 J0.2081 F30.
N303 G03 X11.2275 Y1.693 Z-0.032 I0.0019 J-0.0312 F30.
N304 G01 X11.2275 Y1.6602 Z-0.032 F30.
N305 G03 X11.2587 Y1.629 Z-0.032 I0.0313 J0. F30.
N306 G01 X11.9288 Y1.629 Z-0.032 F30.
N307 G03 X11.9601 Y1.6602 Z-0.032 I0. J0.0313 F30.
N308 G01 X11.9611 Y1.628 Z-0.032 F30.
N309 G01 X11.5123 Y1.628 Z-0.032 F30.
N310 G01 X11.2609 Y1.628 Z-0.032 F30.
N311 G01 X11.1779 Y1.628 Z-0.032 F30.
N312 G01 X11.1758 Y1.628 Z-0.032 F30.
N313 G01 X10.4756 Y1.628 Z-0.032 F30.
N314 G01 X10.4756 Y2.2192 Z-0.032 F30.
N315 G03 X10.4443 Y2.2505 Z-0.032 I-0.0313 J0. F30.
N316 G01 X10.3258 Y2.2505 Z-0.032 F30.
N317 G01 X10.3258 Y2.4529 Z-0.032 F30.
N318 G01 X10.4443 Y2.4529 Z-0.032 F30.
N319 G03 X10.4756 Y2.4841 Z-0.032 I0. J0.0313 F30.
N320 G01 X10.4756 Y2.4934 Z-0.032 F30.
N321 G01 X10.4756 Y3.0431 Z-0.032 F30.
N322 G01 X10.4756 Y3.0753 Z-0.032 F30.
N323 G01 X10.9244 Y3.0753 Z-0.032 F30.
N324 G01 X11.1758 Y3.0753 Z-0.032 F30.
N325 G01 X11.2587 Y3.0753 Z-0.032 F30.
N326 G01 X11.2609 Y3.0753 Z-0.032 F30.
N327 G01 X11.9611 Y3.0753 Z-0.032 F30.
N328 G01 X11.9611 Y2.4841 Z-0.032 F30.
N329 G03 X11.9923 Y2.4529 Z-0.032 I0.0313 J0. F30.
N330 G01 X12.1049 Y2.4529 Z-0.032 F30.
N331 G01 X12.1049 Y2.4196 Z-0.032 F30.
N332 G01 X12.1049 Y2.2505 Z-0.032 F30.
N333 G01 X11.9923 Y2.2505 Z-0.032 F30.
N334 G03 X11.9611 Y2.2192 Z-0.032 I0. J-0.0313 F30.
N335 G01 X11.9611 Y2.2099 Z-0.032 F30.
N336 G01 X11.9611 Y1.6602 Z-0.032 F30.
N337 G00 X11.9611 Y1.6602 Z0.1
N338 M09
N339 M05
( NEXT CUT - NEXT TOOL)
(JOB 2  CONTOUR)
(FEATURE PROFILE)
N340 T2 M06
N341 G00 G90 G54 X11.065 Y3.6646 S10000 M03
N342 G00 X11.065 Y3.6646 Z0.1 M08
N343 G01 X11.065 Y3.6646 Z-0.21 F20.
N344 G01 X11.065 Y3.5741 Z-0.21 F20.
N345 G01 X10.8839 Y3.5741 Z-0.21 F20.
N346 G01 X10.8839 Y3.7552 Z-0.21 F20.
N347 G01 X11.065 Y3.7552 Z-0.21 F20.
N348 G01 X11.065 Y3.6646 Z-0.21 F20.
N349 G00 X11.065 Y3.6646 Z0.1
N350 G00 X11.3711 Y3.6646 Z0.1
N351 G01 X11.3711 Y3.6646 Z-0.21 F20.
N352 G01 X11.3711 Y3.7552 Z-0.21 F20.
N353 G01 X11.5522 Y3.7552 Z-0.21 F20.
N354 G01 X11.5522 Y3.5741 Z-0.21 F20.
N355 G01 X11.3711 Y3.5741 Z-0.21 F20.
N356 G01 X11.3711 Y3.6646 Z-0.21 F20.
N357 G00 X11.3711 Y3.6646 Z0.1
N358 G00 X11.3711 Y4.1518 Z0.1
N359 G01 X11.3711 Y4.1518 Z-0.21 F20.
N360 G01 X11.3711 Y4.2424 Z-0.21 F20.
N361 G01 X11.5522 Y4.2424 Z-0.21 F20.
N362 G01 X11.5522 Y4.0613 Z-0.21 F20.
N363 G01 X11.3711 Y4.0613 Z-0.21 F20.
N364 G01 X11.3711 Y4.1518 Z-0.21 F20.
N365 G00 X11.3711 Y4.1518 Z0.1
N366 G00 X11.065 Y4.1518 Z0.1
N367 G01 X11.065 Y4.1518 Z-0.21 F20.
N368 G01 X11.065 Y4.0613 Z-0.21 F20.
N369 G01 X10.8839 Y4.0613 Z-0.21 F20.
N370 G01 X10.8839 Y4.2424 Z-0.21 F20.
N371 G01 X11.065 Y4.2424 Z-0.21 F20.
N372 G01 X11.065 Y4.1518 Z-0.21 F20.
N373 G00 X11.065 Y4.1518 Z0.1
N374 G00 X10.5778 Y4.3955 Z0.1
N375 G01 X10.5778 Y4.3955 Z-0.21 F20.
N376 G01 X10.5778 Y3.5741 Z-0.21 F20.
N377 G01 X10.3967 Y3.5741 Z-0.21 F20.
N378 G01 X10.3967 Y5.2168 Z-0.21 F20.
N379 G01 X10.5778 Y5.2168 Z-0.21 F20.
N380 G01 X10.5778 Y4.3955 Z-0.21 F20.
N381 G00 X10.5778 Y4.3955 Z0.1
N382 G00 X10.9744 Y4.7296 Z0.1
N383 G01 X10.9744 Y4.7296 Z-0.21 F20.
N384 G01 X11.065 Y4.7296 Z-0.21 F20.
N385 G01 X11.065 Y4.5485 Z-0.21 F20.
N386 G01 X10.8839 Y4.5485 Z-0.21 F20.
N387 G01 X10.8839 Y4.7296 Z-0.21 F20.
N388 G01 X10.9744 Y4.7296 Z-0.21 F20.
N389 G00 X10.9744 Y4.7296 Z0.1
N390 G00 X11.065 Y5.1263 Z0.1
N391 G01 X11.065 Y5.1263 Z-0.21 F20.
N392 G01 X11.065 Y5.0357 Z-0.21 F20.
N393 G01 X10.8839 Y5.0357 Z-0.21 F20.
N394 G01 X10.8839 Y5.2168 Z-0.21 F20.
N395 G01 X11.065 Y5.2168 Z-0.21 F20.
N396 G01 X11.065 Y5.1263 Z-0.21 F20.
N397 G00 X11.065 Y5.1263 Z0.1
N398 G00 X11.3711 Y5.1263 Z0.1
N399 G01 X11.3711 Y5.1263 Z-0.21 F20.
N400 G01 X11.3711 Y5.2168 Z-0.21 F20.
N401 G01 X11.5522 Y5.2168 Z-0.21 F20.
N402 G01 X11.5522 Y5.0357 Z-0.21 F20.
N403 G01 X11.3711 Y5.0357 Z-0.21 F20.
N404 G01 X11.3711 Y5.1263 Z-0.21 F20.
N405 G00 X11.3711 Y5.1263 Z0.1
N406 G00 X11.4617 Y4.7296 Z0.1
N407 G01 X11.4617 Y4.7296 Z-0.21 F20.
N408 G01 X11.5522 Y4.7296 Z-0.21 F20.
N409 G01 X11.5522 Y4.5485 Z-0.21 F20.
N410 G01 X11.3711 Y4.5485 Z-0.21 F20.
N411 G01 X11.3711 Y4.7296 Z-0.21 F20.
N412 G01 X11.4617 Y4.7296 Z-0.21 F20.
N413 G00 X11.4617 Y4.7296 Z0.1
N414 G00 X12.0394 Y4.3955 Z0.1
N415 G01 X12.0394 Y4.3955 Z-0.21 F20.
N416 G01 X12.0394 Y3.5741 Z-0.21 F20.
N417 G01 X11.8583 Y3.5741 Z-0.21 F20.
N418 G01 X11.8583 Y5.2168 Z-0.21 F20.
N419 G01 X12.0394 Y5.2168 Z-0.21 F20.
N420 G01 X12.0394 Y4.3955 Z-0.21 F20.
N421 G00 X12.0394 Y4.3955 Z0.1
N422 G00 X12.0394 Y10.1679 Z0.1
N423 G01 X12.0394 Y10.1679 Z-0.21 F20.
N424 G01 X12.0394 Y5.523 Z-0.21 F20.
N425 G01 X11.8583 Y5.523 Z-0.21 F20.
N426 G01 X11.8583 Y14.8128 Z-0.21 F20.
N427 G01 X12.0394 Y14.8128 Z-0.21 F20.
N428 G01 X12.0394 Y10.1679 Z-0.21 F20.
N429 G00 X12.0394 Y10.1679 Z0.1
N430 G00 X11.5522 Y10.1679 Z0.1
N431 G01 X11.5522 Y10.1679 Z-0.21 F20.
N432 G01 X11.5522 Y5.523 Z-0.21 F20.
N433 G01 X11.3711 Y5.523 Z-0.21 F20.
N434 G01 X11.3711 Y14.8128 Z-0.21 F20.
N435 G01 X11.5522 Y14.8128 Z-0.21 F20.
N436 G01 X11.5522 Y10.1679 Z-0.21 F20.
N437 G00 X11.5522 Y10.1679 Z0.1
N438 G00 X11.065 Y10.1679 Z0.1
N439 G01 X11.065 Y10.1679 Z-0.21 F20.
N440 G01 X11.065 Y5.523 Z-0.21 F20.
N441 G01 X10.8839 Y5.523 Z-0.21 F20.
N442 G01 X10.8839 Y14.8128 Z-0.21 F20.
N443 G01 X11.065 Y14.8128 Z-0.21 F20.
N444 G01 X11.065 Y10.1679 Z-0.21 F20.
N445 G00 X11.065 Y10.1679 Z0.1
N446 G00 X10.5778 Y10.1679 Z0.1
N447 G01 X10.5778 Y10.1679 Z-0.21 F20.
N448 G01 X10.5778 Y5.523 Z-0.21 F20.
N449 G01 X10.3967 Y5.523 Z-0.21 F20.
N450 G01 X10.3967 Y14.8128 Z-0.21 F20.
N451 G01 X10.5778 Y14.8128 Z-0.21 F20.
N452 G01 X10.5778 Y10.1679 Z-0.21 F20.
N453 G00 X10.5778 Y10.1679 Z0.1
N454 M09
N455 M05
( RELOAD FIRST TOOL)
( END OF FILE)
( END OF PROGRAM)
N456 T1 M06
N457 M30 G00 X.0 y.0
Re: y axis
« Reply #5 on: June 03, 2009, 02:41:28 PM »
This is what I get wioth your code, does that look correct? If it is then please attach your xml. You need to use the aditional options button at the lower left of the reply page and then browse to your xml. You will however have to rename it first so go to the Mach3 folder and right click and copy your xml then paste it to the desktop, then right click and rename it Pherf3.xml and then attach to the forum.
Offline PCH
  •  80 80
Re: y axis
« Reply #6 on: June 03, 2009, 04:01:48 PM »
I keep getting this
Sorry! There is already an attachment with the same filename as the one you tried to upload. Please rename the file and try again.
After I attach and post.  I have renamed it as you suggested
Offline PCH
  •  80 80
Re: y axis
« Reply #7 on: June 03, 2009, 04:03:49 PM »
try again
Re: y axis
« Reply #8 on: June 03, 2009, 04:08:59 PM »
Ok seems you have already posted a xml with the Pherf3 name, the forum only accepts a file once so each time you would need to change the name.
Just loaded your xml and I get exactly the same as posted above, is that the correct toolpath?
Offline PCH
  •  80 80
Re: y axis
« Reply #9 on: June 03, 2009, 06:36:29 PM »
yes
