Hello Guest it is November 12, 2026, 07:41:11 AM
Author Topic: OD facing wizard cuts a taper not parallel  (Read 11228 times)
Offline berty
  •  74 74
« on: June 03, 2009, 03:42:35 AM »
I am still in convertion and setting up stage with lathe and occasionally i use it in manual to do small jobs
I tried to use the OD facing wizard but the machine gave a perfect tapper cut the when tool approached next cut the depth of cut stayed the same
I think it must be an offset problem but I am at a loss where to look for it
Maybee some one knows the answer
Cheers Bert
Re: OD facing wizard cuts a taper not parallel
« Reply #1 on: June 03, 2009, 04:36:26 AM »
Can you post the code that is getting put out please, I have used the wizard before and it worked fine but it was a long time ago.
Offline berty
  •  74 74
« Reply #2 on: June 04, 2009, 05:33:41 AM »
I will try to post it
cheers bert
