Hello Guest it is October 24, 2026, 02:46:47 AM
Author Topic: Can use both LTP Port  (Read 16215 times)
Offline tivoi
  •  29 29
« on: August 15, 2006, 08:26:13 AM »
I want use both LTP 1 and LTP 2, because i want use encoder for xyz axis. Need too much input, 1 LTP just have 5 input. If i use LTP 2 port I have more than 17 input. That right?  ??? ??? ???
Re: Can use both LTP Port
« Reply #1 on: August 15, 2006, 01:56:29 PM »
That sounds about right
www.newfangledsolutions.com
www.machsupport.com
Offline tivoi
  •  29 29
« Reply #2 on: April 11, 2007, 10:23:26 PM »
any body try use 2 printer port? how to setting Mach3
« Reply #3 on: April 11, 2007, 11:00:54 PM »
Yes, you can use both. You need to make sure the port address for port 2 is right and that it is enabled.
Offline tivoi
  •  29 29
« Reply #4 on: April 13, 2007, 08:48:02 PM »
thanks for your replay . but i had more question. address of LTP 2. where i can get it?
« Reply #5 on: April 13, 2007, 09:22:11 PM »
Look in control panel of windows then go to the system icon then hardware then  device manager and look under ports. Right click your second port and go to the resources tab, the address will be the first four digits in the I/0 range.
Offline tivoi
  •  29 29
« Reply #6 on: April 14, 2007, 06:30:41 AM »
thanks you very much  :)
« Reply #7 on: April 22, 2007, 08:01:09 PM »
Yeap. See picture
Scott
« Last Edit: April 22, 2007, 08:12:46 PM by Chaoticone »
