Hello Guest it is November 26, 2026, 03:03:47 AM
Author Topic: Single Line GCode window  (Read 9778 times)
« on: May 26, 2009, 04:31:55 PM »
Hi all,
I did a search and came up empty so hopefully this has not been previously answered.
I am creating a screen and would like to have only the currently executed (normally highlighted white) GCode line displayed.
When I try to scale the GCode window the text gets tiny.
Is it possible
Re: Single Line GCode window
« Reply #1 on: May 26, 2009, 05:31:31 PM »
In Screen4 (The screen building program) double click the G code screen. At the bottom of the pop up is a box where you set number of lines of code. Then you can size the box for the size text you want.
« Reply #2 on: May 26, 2009, 06:14:15 PM »
That was easier than I thought.  Thanks for your response.
