Hello Guest it is October 15, 2026, 10:31:45 PM
Author Topic: Index switch / limit switch  (Read 25156 times)
Offline TRX
  •  2 2
Re: Index switch / limit switch
« Reply #10 on: May 23, 2009, 03:05:51 AM »
 Laser?  Do you have pictures of this somewhere?  Commentary?
 Of all the work it took to do my CNC conversion, the limit switches were the biggest pain in the posterior, and I have this bad feeling that they're going to be a problem eventually...
Offline jimpinder
  •  1,232 1,232
  • Wakefield, West Yorks, UK
« Reply #11 on: May 25, 2009, 03:27:56 AM »
The two laser modules, which are 2 inches long and 1/2 inch dismater (certainly less that that) run off a 5 volt supply. You can get tham fitted with lenses to give amore focused output. I got mine from Maplin (UK firm) at £10 each. The dtectors are three wire Schmidt trigger devices, giving an instantaneous change fro 5 to 0 v if hit by a laser beam. They drive TTL and CMOS directly.
I have my lasers mounted on the table shining onto detectors mounted on the lathe body. There is no physical contact between the two, indeed, they with work over a long distance if required.
Excellent, repeatable results, to less than 2/100ths of a mm.
