Hello Guest it is November 19, 2026, 09:33:39 AM
Author Topic: Radius to end of arc issue  (Read 11974 times)
« on: May 18, 2009, 09:52:28 AM »
Newbie here.  I am setting up to run my table top router for the first time using Mach 3.  I loaded my first G-Code and I am not able to get the program to run.  I am getting a message that reads "Radius to end of Arc differs from radius to startline 23"
Can someone please help this newbie out?
Re: Radius to end of arc issue
« Reply #1 on: May 18, 2009, 09:54:08 AM »
Change the IJ mode in General Config.
« Reply #2 on: August 21, 2009, 07:45:01 AM »
I'm having the same problem.
I don't understand what mode to change in config.
Eddie
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #3 on: August 21, 2009, 01:42:04 PM »
Hi, Eddie
This is probilly what you need to change or put a G90.1 or G91.1 in the top of your G code file.
Hope this helps, Chip
« Reply #4 on: August 21, 2009, 04:58:59 PM »
Try taking a look at the ACR Motion wirte up in Members Docs. It's for a Lathe but it covers a lot on arc's info.
