Hello Guest it is November 01, 2026, 12:18:48 PM
Author Topic: New Lcam with post processor  (Read 52591 times)
Re: New Lcam with post processor
« Reply #10 on: August 15, 2006, 04:38:08 AM »
Okay,
Chip and John I should have time to get that all working tonight. I worked with Art last night with Art on the multiaxis probing :) So i will stop working on the toys and get back to work  :'(
I am off Thursday (from work) so I better have it fixed this weekend!
www.newfangledsolutions.com
www.machsupport.com
« Reply #11 on: August 16, 2006, 09:13:48 PM »
The depth needs to be set to a negitive number :) I needed to add Positive cut heights for an OEM :(
Looking at the other stuff now :)
www.machsupport.com
« Reply #12 on: August 17, 2006, 06:55:00 AM »
If you hava a negitive depth it seems to be working well..
Chip i am now off to see what I can do to get you fixed :)
www.machsupport.com
« Reply #13 on: August 17, 2006, 06:58:09 AM »
Chip I am going to change the post so you can cut points. You will not be able to use the can cycle because I don't think you can have M3's and M5's in a can cycle :(
I should have this fixed in a few
www.machsupport.com
« Reply #14 on: August 17, 2006, 07:42:43 AM »
Other then the power going out for a bit this was fun ot fix :) The new Post processor is making it SO much faster to make changes with out beaking other things in the program.. I changed the default post in Lcam but I know you are not running a plasma so you can change the post to make your water jet run  :o If you have trouble I will give you a hand
Brian
www.machsupport.com
« Reply #15 on: August 17, 2006, 08:12:27 AM »
There is also a new rev on the FTP server
Please have a look and see if that fixes your trouble.. If you geys are happy I will start to finisha few other things that I am working on...
Thank you
Brian
www.machsupport.com
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #16 on: August 17, 2006, 12:57:50 PM »
Hi, Brian
There few items that still exist ill post them separately Ver.2.61.
If I load a DXF file and enter a Final Depth or a Rapid Hight without changing the Per Pass value upon clicking OK, LasyCam will lockup.
If I load a dxf file and set the Per Pass value to .5, then I can set Final Depth and Start Depth without lockup.
At this point I can change the Per Pass back to Default Value of 1 and  have no lockup problem.
This is without closing LC and restarting, once shutdown and restarted it will freeze again with out changing the value in Per Pass if Final Depth or Rapid Hight are used.
If I change Per Pass to .5 close the window then change it back to 1 default value again then the problem is gone till restart of LC again.
If there are multipal layers then Per Pas value has to be changed in all layers
Windows  End Task will shut LC down after freeze .
Thank's Chip
Offline Chip
  •  2,055 2,055
« Reply #17 on: August 17, 2006, 01:35:46 PM »
Hi Brian
The Dot/ Peirce is working now but there are some M5 missing now that were there before see below.
Also the first M3 has a S0 generates a error VB Editor Window.
N1 (File test55Dotpolyline )
N2 (File Posted in Plasma Mode)
N3 (Thursday, August 17, 2006)
N4 G90 G80 G40 G91.1
N5 G0  Z0.0000
N6 G0  X0.0000  Y0.5020
N7 G0  Z0.0000
N8 Z0.0000
N9 M3 S0(PLasma On);--------the S0 generates error, shoudent be there in plasma Mode
N10 G4 P1.0000
N11 G1  Y1.0040  F111.00
N12  X1.0000
N13  Y0.0000
N14  X0.0000
N15  Y0.5020
N16 G4 P1.0000
    M5;--------------------------------------------------------------missing now
N17 G0  Z0.0000
N18 G0  X1.6996  Y1.6058
N19 G0  Z0.0000
N20 Z0.0000
N21 M3 S0(PLasma On)
N22 G4 P1.0000
N23 G2  X2.5020  Y2.0080  I0.3004  J0.4022
N24  X1.6996  Y1.6058  I-0.5020  J0.0000
N25 G4 P1.0000
    M5---------------------------------------------------------------missing now
N26 G0  Z0.0000
N27 G0  X3.0000  Y1.0040
N28 G0  Z0.0000
N29 Z0.0000
N30 M3 S0(PLasma On)
N31 G4 P1.0000
N32 G1  X4.0000  Y2.0080
N33  Y0.0000
N34  X2.0000
N35  X3.0000  Y1.0040
N36 G4 P1.0000
    M5;-------------------------------------------------------------missing now
N37 G0  Z0.0000
N38 G0  X3.0000  Y1.2500
N39 G0  Z0.0000
N40 Z0.0000
N41 M3 S0(PLasma On)
N42 G4 P1.0000
N43 G1 Z0.0000 F11.00
N44 G4 P1.0000
N45 M5(Plasma Off)
N46 G0 Z0.0000
N47 G4 P1.0000
N48 G0 X3.7500  Y2.0000
N49 Z0.0000
N50 M3(PLasma On)
N51 G4 P1.0000
N52 G1 Z0.0000 F11.00
N53 G4 P1.0000
N54 M5(Plasma Off)
N55 G0 Z0.0000
N56 G4 P1.0000
N57 G0 X3.7500  Y2.7500
N58 Z0.0000
N59 M3(PLasma On)
N60 G4 P1.0000
N61 G1 Z0.0000 F11.00
N62 G4 P1.0000
N63 M5(Plasma Off)
N64 G0 Z0.0000
N65 G4 P1.0000
N66 G0 X0.2500  Y2.7500
N67 Z0.0000
N68 M3(PLasma On)
N69 G4 P1.0000
N70 G1 Z0.0000 F11.00
N71 G4 P1.0000
N72 M5(Plasma Off)
N73 G0 Z0.0000
N74 G4 P1.0000
N75 G0 X0.2500  Y1.5000
N76 Z0.0000
N77 M3(PLasma On)
N78 G4 P1.0000
N79 G1 Z0.0000 F11.00
N80 G4 P1.0000
N81 M5(Plasma Off)
N82 G0 Z0.0000
N83 G4 P1.0000
N84 G0  Z0.0000
N85 G0  X4.0000  Y2.2500
N86 G0  Z0.0000
N87 Z0.0000
N88 M3 S0(PLasma On)
N89 G4 P1.0000
N90 G1  Y2.7500  F111.00
N91 G3  X3.7500  Y3.0000  I-0.2500  J0.0000
N92 G1  X0.2500
N93 G3  X0.0000  Y2.7500  I-0.0000  J-0.2500
N94 G1  Y1.5000
N95 G3  X0.2500  Y1.2500  I0.2500  J-0.0000
N96 G1  X2.7500
N97 G4 P1.0000
    M5;-------------------------------------------------------------needs to be added for plasma
N98 Z0.0000
N99 M5 M9
N100 X0.0 Y0.0
N101 G40 G80M30
Thank's Chip
« Reply #18 on: August 17, 2006, 07:26:23 PM »
Could you see if you can edit the plasma post to get it to work the way you would like? This will help me with the post :)
www.machsupport.com
Offline Chip
  •  2,055 2,055
« Reply #19 on: August 17, 2006, 07:41:42 PM »
Hi, Brian
Just read your last post that's what I am dooing now,------ Please read this post though.
The G81 caned cycle was something LC 2.60 chose not me, I figured you were going to pull a rabbit out of your hat.
The -1 worked one time for me, If I change the default Value in Per Pass from 1 to .5 then OK, then set Per Pass back to 1 then I can enter - or + in  Final Depth and or Rapid Hight without LasyCam locking UP.
This is needed in all layers to keep it from locking up if Final Depth and or Rapid Hight are changed layer by layer.
Could it be when LC loads that the Default 1 value is-sent being properly loaded in some sort of Variable location ?.
Could you make the Gcode post also show Default Post / Plasma or User post"Plasma***.PST is being used at top of file.
Thank's for the plasma example.PST it's a little clearer where your going with this, Just allot of soreting this out for me and allot of cleaning up the code to remove previous structure to streamline for you.
On other item, LC saves my changes in the LC.XML But Never reloads any of them on startup, write now I am only using one file for testing.
Everything is in Mach3 in propper Sub. Dir's.
Thank's Chip
« Last Edit: August 17, 2006, 08:35:19 PM by afn09556 »
