Hello Guest it is August 13, 2026, 06:01:54 AM
Author Topic: Moving work within table display  (Read 15648 times)
« on: May 14, 2009, 11:48:13 PM »
         Guys,
             I'm able to move a piece of work closer to the X=0, Y=0 point, but the red traces that originated at the XY point are now redirected off the table display, and then back to the work piece. Is there a way to change this, and have the traces originate at the Xy point directly to the work piece? I hope you can understand what I'm trying to accomplish.
Marv Frankel
Los Angeles
Re: Moving work within table display
« Reply #1 on: May 15, 2009, 12:00:49 AM »
Hi Marv,
  I'll try.
If X0 and Y0 in your program are on your part, not off in the distance, jog x and y to the 0,0,point, Zero the X and Y DRO's, then regen the display.
See what you get then.
Not sure what you mean,
RC
« Reply #2 on: May 15, 2009, 12:04:39 AM »
I seems your ORIGIN of the drawing for your part is away from the part itself.
Post your code file if you wish.
RC
« Reply #3 on: May 15, 2009, 12:29:16 AM »
        RC,
          Here's the G-code file. Thanks for the help.
Marv Frankel
« Reply #4 on: May 15, 2009, 06:13:28 AM »
Looks like your part 0,0 is not on the part but is at the tool change position.
Try jogging to the first hole, enter 10.182 in the X dro... and 3.613 in the Y dro.
I think 0,0 is normally on a feature of the part.
« Reply #5 on: May 17, 2009, 08:13:57 AM »
       I solved a great deal of the problem by going back into my AutoCad drawing, and relocating the drawing to the hypothetical X-Y Zero point of the screen, and exporting that relocated drawing to a new DXF file. When I opened the DXF file in D2nc, and posted it to G-code, it appeared far closer to the X-Y Zero in Mach3. Thanks for listening to a somewhat confused Mach3 user.
Marv Frankel
Los Angeles
« Reply #6 on: May 17, 2009, 01:58:07 PM »
No prob Marv,
 Happy I could help.  :)
I'm relatively new at this and struggling through it as well.
RC
