Hello
Guest
it is
November 19, 2026, 12:56:16 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Moving work within table display
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Moving work within table display (Read 16425 times)
Marv Frankel
7
on:
May 14, 2009, 11:48:13 PM »
Guys,
I'm able to move a piece of work closer to the X=0, Y=0 point, but the red traces that originated at the XY point are now redirected off the table display, and then back to the work piece. Is there a way to change this, and have the traces originate at the Xy point directly to the work piece? I hope you can understand what I'm trying to accomplish.
Marv Frankel
Los Angeles
Logged
Overloaded
4,923
Re: Moving work within table display
Reply #1 on:
May 15, 2009, 12:00:49 AM »
Hi Marv,
I'll try.
If X0 and Y0 in your program are on your part, not off in the distance, jog x and y to the 0,0,point, Zero the X and Y DRO's, then regen the display.
See what you get then.
Not sure what you mean,
RC
Logged
Overloaded
4,923
Reply #2 on:
May 15, 2009, 12:04:39 AM »
I seems your ORIGIN of the drawing for your part is away from the part itself.
Post your code file if you wish.
RC
Logged
Marv Frankel
7
Reply #3 on:
May 15, 2009, 12:29:16 AM »
RC,
Here's the G-code file. Thanks for the help.
Marv Frankel
Logged
Overloaded
4,923
Reply #4 on:
May 15, 2009, 06:13:28 AM »
Looks like your part 0,0 is not on the part but is at the tool change position.
Try jogging to the first hole, enter 10.182 in the X dro... and 3.613 in the Y dro.
I think 0,0 is normally on a feature of the part.
Logged
Marv Frankel
7
Reply #5 on:
May 17, 2009, 08:13:57 AM »
I solved a great deal of the problem by going back into my AutoCad drawing, and relocating the drawing to the hypothetical X-Y Zero point of the screen, and exporting that relocated drawing to a new DXF file. When I opened the DXF file in D2nc, and posted it to G-code, it appeared far closer to the X-Y Zero in Mach3. Thanks for listening to a somewhat confused Mach3 user.
Marv Frankel
Los Angeles
Logged
Overloaded
4,923
Reply #6 on:
May 17, 2009, 01:58:07 PM »
No prob Marv,
Happy I could help.
I'm relatively new at this and struggling through it as well.
RC
Logged
Print
Pages:
1
Go Up
« previous
next »
