Hello
Guest
it is
November 19, 2026, 12:44:00 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
mach 3 plasma
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: mach 3 plasma (Read 14578 times)
bbrown2005
17
mach 3 plasma
on:
May 13, 2009, 07:47:09 PM »
hi, i was wondering how do you set the width of the kerf cut is there a setting for that or do i have to compensate for that each cut
tripleblack
128
Re: mach 3 plasma
Reply #1 on:
May 14, 2009, 11:20:33 AM »
hi, what i do create an offset in cad . i use turbocad pro 10. my kerf is about .07. after i have drawn my part , i jion polyline, then offset .035, delete the original, and save.convert with lazycam .
bbrown2005
17
Re: mach 3 plasma
Reply #2 on:
May 15, 2009, 06:52:43 PM »
thanks i did not want to sound stupid for asking but that works great because i have turbo cad v10 also thanks
tripleblack
128
Re: mach 3 plasma
Reply #3 on:
May 17, 2009, 07:52:17 PM »
another tip. make sure you save as a r12 dxf.i find that if you save as a r14 dxf,and there are arcs, lazycam will insert a m3 at an arc in the middle of a cut.a real annoyance to have happen.you can get rid of the arcs by exploding three times and then joining polyline, but if the arc is a large radius, will be faceted.
bbrown2005
17
Re: mach 3 plasma
Reply #4 on:
May 17, 2009, 08:11:44 PM »
thanks. i am new with the mach plasma i have been working on my table for about 2 years and excited to have it going thanks, ben
Print
Pages:
1
Go Up
« previous
next »
