Hello Guest it is November 08, 2026, 03:01:32 AM
Author Topic: mach 3 plasma  (Read 14454 times)
mach 3 plasma
« on: May 13, 2009, 07:47:09 PM »
hi, i was wondering  how do you set the width of the kerf cut is there a setting for that or do i have to compensate for that each cut
Re: mach 3 plasma
« Reply #1 on: May 14, 2009, 11:20:33 AM »
hi, what i do create an offset in cad . i use turbocad  pro 10. my kerf is about .07. after i have drawn my part , i jion polyline, then offset .035, delete the original, and save.convert with lazycam .
Re: mach 3 plasma
« Reply #2 on: May 15, 2009, 06:52:43 PM »
thanks i did not want to sound stupid for asking but that works great because i have turbo cad v10 also thanks
Re: mach 3 plasma
« Reply #3 on: May 17, 2009, 07:52:17 PM »
another tip. make sure you save as a r12 dxf.i find that if you save as a r14 dxf,and  there are arcs, lazycam will insert a m3 at an arc in the middle of a cut.a real annoyance to have happen.you can get rid of the arcs by exploding three times and then joining polyline, but if the arc is  a large radius, will be faceted.
Re: mach 3 plasma
« Reply #4 on: May 17, 2009, 08:11:44 PM »
thanks. i am new with the mach plasma i have been working on my table for about 2 years and excited to have it going thanks, ben
