Hello Guest it is October 20, 2026, 03:09:00 PM
Author Topic: dell optiplex  (Read 15794 times)
dell optiplex
« on: August 11, 2006, 11:53:36 AM »
Hi, i have 3 dell optiplex series 110 115 and 200. the 110 works fine on mach3. the other two appear to have bad parallel ports. i am wundering if these might suffer from low voltage output on the parallel port? previous condition of computers is unknown. ideas anyone? cul brian f.
Re: dell optiplex
« Reply #1 on: August 12, 2006, 08:00:49 AM »
Do you have a meter that you can check it with?
www.newfangledsolutions.com
www.machsupport.com
Re: dell optiplex
« Reply #2 on: August 12, 2006, 08:48:22 AM »
Hi, yes i do, havent taken time to check. my computer guru suggest it might work on a different interup.
i will probably sometime today test it with a meter. all of the dell p4-1700 and p4-2000 have been tested and run the machine fine. (hobbycnc drives).  thanks for the reply, will keep you posted on the results. cul brian f.
Re: dell optiplex
« Reply #3 on: August 12, 2006, 10:44:43 AM »
I bought a GX100 from Ebay for $40 and it works fine. P3 1.1Ghz.
Re: dell optiplex
« Reply #4 on: August 12, 2006, 11:32:37 AM »
ok, that is good to hear, what drive board are you using? thanks, brian f.
Re: dell optiplex
« Reply #5 on: August 12, 2006, 02:28:45 PM »
Xylotex.
Re: dell optiplex
« Reply #6 on: August 12, 2006, 02:34:15 PM »
ok, always nice to know, i run Hobbycnc boards and steppers but soon will hook up and try servo drive thru a Skyco board.
cul brian f.
