Hello Guest it is October 23, 2026, 04:12:27 PM
Author Topic: axis direction  (Read 12116 times)
axis direction
« on: May 11, 2009, 07:27:22 PM »
Hopefully this is a simple question.  How do I switch my axis direction.  I would like to switch z- to z+.  It seems like it should be in the the xml but I can not find it.
Thanks!
Re: axis direction
« Reply #1 on: May 11, 2009, 07:32:12 PM »
Homing/Limits screen, check "Reversed"
Re: axis direction
« Reply #2 on: May 11, 2009, 09:47:46 PM »
simply invert the axis under "motor output" settings... or you can change your hotkey (Config>System HotKeys) but the 2nd step will not change how your cnc will run under the same g code.
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: axis direction
« Reply #3 on: May 12, 2009, 02:51:28 PM »
Hi, Kurt
You should use Config, Homing & Limits screen "Reversed" Column), Using Motor Output's can cause Issues with some Axis Control Board's.
Chip
