Hello
Guest
it is
November 13, 2026, 08:39:22 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
SPINDLE WON'T SHUT DOWN
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: SPINDLE WON'T SHUT DOWN (Read 17212 times)
jordan21
11
on:
May 07, 2009, 06:48:20 PM »
Any ideas why my spindle won't completely stop. When I get finished running a program the spindle winds down from 18000 to around 3000 rpm but won't completely turnoff. On the mach screen it shows it as off but on my vfd it hovers around 3000 rpm. The only way to get it stopped is to type 0 in the mach screen and hit the spindle button. Does anyone have any ideas on what might be happening?
Chaoticone
5,624
Precision Chaos
Re: SPINDLE WON'T SHUT DOWN
Reply #1 on:
May 07, 2009, 07:52:35 PM »
Sounds like maybe you min. speed for the pulley it is running may be 3000. If so, change it to 0 and see if that cures it. Config, spindle pulley.
If you could see the things I have in my head, you would be laughing too.
jordan21
11
Reply #2 on:
May 07, 2009, 08:01:14 PM »
no, my the minimum is already at 0.
Chaoticone
5,624
Precision Chaos
Reply #3 on:
May 07, 2009, 09:10:13 PM »
Tell us more about your setup. How are you controlling the analog to your VFD?
jordan21
11
Reply #4 on:
May 07, 2009, 09:14:13 PM »
i've got a bob campbell b/o board with a seperate sound logic spindle speed board.
M250cnc
591
Reply #5 on:
May 08, 2009, 10:41:39 AM »
You should set your system as follows.
With the VFD disconnected from the supply.
With speed set to maximum rpm you should see +10v to the control pin to the VFD then +0v when set at Zero rpm
This is achieved with the ports and pins settings
Then you also set a relay to control your spindle ON/OFF
You are not currently turning off your motor just turning it to minimum "Big Difference"
Phil
Print
Pages:
1
Go Up
« previous
next »
