Hello Guest it is October 20, 2026, 10:25:35 PM
Author Topic: Uninstall Mach3  (Read 16889 times)
Uninstall Mach3
« on: April 26, 2009, 04:47:11 PM »
I'm still having problems with my Mach3 not communicating with the parallel port so I tried to reinstall Mach3.
When I uninstalled Mach3 I just happened to have the DRO's at values other than zero, now when I reinstall the DRO's stay at the same value. This suggests to me that my uninstall didn't remove everything from my computer.
What do I have to do for a full uninstall? Am I missing some drivers or something similar?
Re: Uninstall Mach3
« Reply #1 on: April 26, 2009, 07:28:09 PM »
You can check to see if the driver was removed in device manager. It will say MachX pulsing engine. You can also delete the Mach 3 folder that is most likely on your c drive. If you have any profiles set up, screen sets or macros you want to keep, save a copy of those on a thumb drive or CD before you delete the folder.
