Hello
Guest
it is
November 15, 2026, 09:18:03 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Problem in sharp corners
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Problem in sharp corners (Read 11036 times)
rceebuilder
33
on:
August 06, 2006, 06:22:48 AM »
I don't know if it is a problem or I do something wrong when I increase the feed rate Mach3 rounds the corners of the cutting path .It is related with the accelaration The more acc is decreased The more the corners is cut round.
Rceebuilder
Logged
Authentic Damsels
ger21
6,295
Re: Problem in sharp corners
Reply #1 on:
August 06, 2006, 08:22:56 AM »
That's a function of Constant Velocity mode. If you need sharp corners, use Exact Stop mode.
Logged
Brian Barker
3,860
Reply #2 on:
August 06, 2006, 06:17:36 PM »
That is a CV problem... There is a way to tell mach 3 to only round so much... Go to the settings page and do the following settings:
CV angle = 45
CV feedrate = 30 anf turn it on...
If you would like to have less rounding make the CV feedrate lower
Logged
Fixing problems one post at a time
www.newfangledsolutions.com
www.machsupport.com
Print
Pages:
1
Go Up
« previous
next »
