Hello Guest it is November 11, 2026, 11:21:53 PM
Author Topic: Feed rate on start up.  (Read 11039 times)
« on: April 22, 2009, 07:06:27 AM »
When I start mach3 the Feed rate is 6 (6mm/min--very slooow)
When i JOG this feed rate is used. I can change it, but next time i start Mach3 it is 6 again. Where can I change this value so it's default?
Offline Greolt
  •  956 956
Re: Feed rate on start up.
« Reply #1 on: April 22, 2009, 08:46:30 AM »
Put it in the initialisation string in general config
F1000 for example.
Greg
« Reply #2 on: April 23, 2009, 01:58:28 AM »
Thanks. That do the trick.
