Hello
Guest
it is
November 11, 2026, 11:13:15 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
FAQs
Feed rate on start up.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Feed rate on start up. (Read 11037 times)
Jens H
15
on:
April 22, 2009, 07:06:27 AM »
When I start mach3 the Feed rate is 6 (6mm/min--very slooow)
When i JOG this feed rate is used. I can change it, but next time i start Mach3 it is 6 again. Where can I change this value so it's default?
Logged
Greolt
956
Re: Feed rate on start up.
Reply #1 on:
April 22, 2009, 08:46:30 AM »
Put it in the initialisation string in general config
F1000 for example.
Greg
Logged
Jens H
15
Reply #2 on:
April 23, 2009, 01:58:28 AM »
Thanks. That do the trick.
Logged
Print
Pages:
1
Go Up
« previous
next »
