Hello Guest it is November 10, 2026, 03:15:54 AM
Author Topic: Quick Step Pulse Motor Tuning Questions Help.  (Read 26463 times)
« on: April 18, 2009, 07:58:45 PM »
I am installing my VFD for spindle control and I'm using the C6 board from CNC4PC and it says in motor tuning under spindle to change the step pulse to 3. Well this changes the step pulses on my X Y and Z axis from 0 to 3 as well, what will this do to the other axis'. Thanks.
Re: Quick Step Pulse Motor Tuning Questions Help.
« Reply #1 on: April 19, 2009, 04:05:55 AM »
It shouldnt do any harm.
« Reply #2 on: April 19, 2009, 02:58:20 PM »
Thanks, what does the step pulse do?
« Reply #3 on: April 19, 2009, 03:12:02 PM »
It basically changes the duration of the pulse ....higher #, longer pulse.
RC
« Reply #4 on: April 19, 2009, 03:13:42 PM »
So how does going from zero to 3 not affect the motors, or is it just a slight delay in the way the pulses get there? I guess it's better to have them slightly longer than too short where the motor can miss a pulse?
« Reply #5 on: April 19, 2009, 03:20:54 PM »
Picture a 12" ruler with 1 pulse per inch.
The pulses could be 1/8" wide, or 1/2" wide.
Same amount of pulses per foot, just wider pulses with less gap in between.
Some electronics and isolated BoB's and such need the longer pulse so it is seen through the system
RC
« Reply #6 on: April 19, 2009, 03:25:58 PM »
Ok, thanks for the explanation, just making sure it won't change anything and make the steppers act funny or mis steps.
« Reply #7 on: April 19, 2009, 03:29:53 PM »
Like HOOD said......it shouldn't, and I'll add.....most likely wont.
It will depend greatly on your overall set-up.
Time will tell.
RC
« Reply #8 on: April 19, 2009, 04:08:23 PM »
LOL, that doesn't sound to reassuring. What should I be looking for?
« Reply #9 on: April 19, 2009, 04:13:04 PM »
What drives do you have?
