Hello Guest it is November 22, 2026, 09:20:11 AM
Author Topic: HOME SWICH NOT REVERSING and LIMIT SWITCH  (Read 12739 times)
« on: April 08, 2009, 03:58:17 AM »
Retrofitting a Sharp mill. I have the x-- limit and x home on one switch with a separate switch for x+. The limit override led is on.
 When I reference x home, X goes to home and stops but will not back off the switch and the limit switch is triggered. To get off the
switch I have to turn off the X-- input. Then when I home it will home and zero the DRO but not move off the switch.
Same problem on the Y and Z
 Robert
Re: HOME SWICH NOT REVERSING and LIMIT SWITCH
« Reply #1 on: April 08, 2009, 04:09:27 AM »
Try with the debounce interval at 2000 and if that halps lower it until the problem again appears and notch up again.
« Reply #2 on: April 08, 2009, 02:25:23 PM »
Thanks that fixed it.   Now I will try to cut the roadrunner.
