Hello Guest it is October 22, 2026, 02:43:29 PM
Author Topic: Feedrate Overides in Lathe  (Read 16857 times)
« on: April 05, 2009, 11:22:18 AM »
I can't seem to get the feedrates to overide, plus or minus, in Mach 3 Lathe (Version R3.042.020) while machine is cutting. I searched here and
messed with OEM codes and Gen config stuff as suggested but no luck?
Danny
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Feedrate Overides in Lathe
« Reply #1 on: April 07, 2009, 12:23:58 AM »
Hi, Danny
I use a Modified Mach3mill.set (screen set) and changed the .set to Lset file type all the over-rides work just fine.
Chip
« Reply #2 on: April 07, 2009, 09:05:21 AM »
Hi Chip,
Could you attach the modified mill.set to email or here?
Thanks  Danny
Offline Chip
  •  2,055 2,055
« Reply #3 on: April 07, 2009, 12:45:32 PM »
Hi, Danny
Hears the Lathe. lset file, Install it in C:Mach3 folder, It's a work in progress screen Lset.
You need also install the Zip file (JPG's) in C:\Mach3\Bitmaps\MillBitmaps folder.
Edit: New 1024 CHIP LATHE D1ACC.set some added items.
Have Fun, Chip
« Last Edit: April 09, 2009, 11:05:20 PM by Chip »
« Reply #4 on: April 07, 2009, 06:25:16 PM »
I too use a modified version of my mill screen as I never liked the Standard turn one, however I was testing for someone a week or two ago and FRO was working fine for me on the standard screen.
 If Chips doesnt sort you out attach your xml and I will have a look see if I can find a problem.
Offline Chip
  •  2,055 2,055
« Reply #5 on: April 09, 2009, 11:04:02 PM »
Hi, Danny
Did you get things working, Just updated/cleaned up the lathe.set a bit Above, Let us know.
Chip
« Reply #6 on: April 10, 2009, 11:02:53 AM »
HI Guys,
Sorry about not answering sooner. I used your modified .lset and it is working just fine, thanks so much.
I also just renamed a mill.set to mill.lset and it works good also
Thanks for helping out as you always do...
Danny
