Hello Guest it is November 01, 2026, 03:25:24 PM
Author Topic: Posting Code Not Work all time  (Read 9533 times)
« on: April 04, 2009, 11:25:50 AM »
Hi, I have problems with G code generation in LazyCam:
When I  import a DXF file, if I generate a G code at this time they create a file, And if the Mach3 is running they load the Gcode.
But when I generate an offset, or a Pocket LazyCam generate layers, but no longer works "Post Code", it says "File posting posting File Complete" but does not create a file that is not sending the gcode to Mach3 ....
I have conducted hundreds of tests, but once generated the offset or Pocket, they stops create GCode..
Any idea what happend?  ???
(I bought the license for Mach3 and I use Llazicam'm version 3.0.0.2)
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: Posting Code Not Work all time
« Reply #1 on: April 04, 2009, 02:26:12 PM »
Hi, AndresRubio
To generated offset or Pocket's, You need a LazyCam License.
Chip
