Hello Guest it is November 22, 2026, 08:00:09 AM
Author Topic: Need some help with new build... Reset Gecko G320 fault causes Y axis to move?  (Read 32050 times)
Finally finished up my wiring last night, or early this morning actually.  Using a smooth stepper with a PMDX-122 on port 1 and a rogersmachine encoder board on port 2.  Can't get the outputs to work on the rogersmachine board, but that is a topic for another thread.
Using G320's to drive the servo's.  I just hooked up the encoders on the servo's and powered them up for the first time last night.  I don't have an oscilloscope for setup of the G320's, is it really required?  I powered it all up and the Gecko's were all faulted like normal when they first power up.  I reset my E-stop switch (actual switch) then pressed my Gecko reset button to clear the power up fault.  The manual says to hold it for 5 secs, at about second number 2, the Y axis ran inwards until my Vise contacted the machine and a fuse blew.
Not sure why it would do this?  I haven't started to setup the motor tuning or made any adjustments on the Gecko's yet.  I thought I had to have it powered in order to do that.
I was able to replace the fuse and try it again.  It is repeatable.  Once I reset the Gecko's, the Y axis moves quickly and I can Push my Gecko Stop button (Grounds the ERR pin on the Gecko's) to halt it.
Any ideas?
Is your encoder hooked up the correctly? Make sure its connections are good.
I'll check on the wiring for that axis tonight.  Thanks
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Hi, Radioactive
Do as "Hood" stated and then, With the 5 volt power on the Gecko, check power to encoder's, Check the A & B encoder pin's on the Gecko for on/Off 5 volt's while moving the motor shaft slowly.
If the A/B pulses are there, Swap the A/B wires around, You should be getting good at hitting the E-Stop by Now.  :D
Hope this Helps, Chip
Getting late again
« Last Edit: April 04, 2009, 02:27:00 AM by Chip »
I found the "B" wire loose at the servo motor terminal strip.  However, once I landed it, and tried to reset the drives the Y axis still moves in the same direction however only a 1/4 inch at a time.  Short movement, pause for one second, moves again, etc.
I tested and found 5V, ground, and 5 V pulses while moving the motor by hand.  I suppose I will swap the A and B wires next.  Not really sure why it would respond this way if they were swapped though?
Offline Chip
  •  2,055 2,055
Hi, Radioactive
Swap the A B wires that should fix it, But sound's like you have the Enable terminal held in Reset all the time.
You should only apply 5 volt power to it to Reset the drive's. Re-read over the paper work.
Chip
Well I looked in the Gecko instructions and it listed that the servo power wiring being backwards could cause this condition.  So I swapped the power leads and all is well.  The drives reset now.
Now I can't seem to clear a Servo drive disable signal, however no Gecko faults are present?  It may be the RogersMachine interface plugin...
Chip, I was holding the Reset button in and trying to count to five.  After 2 seconds, the drive would move a 1/4 inch, pause for a second, and repeat.  All the while I was holding the reset button in.
OK, removed the RogerMachine plugin for now and no more servo drive disable.  So I went thru the motor tuning section and setup the servo info as appropriate.  I can reset the E-stop and it will hold it's position.  However using the jog menu nothing moves?  Mach 3 shows the position should be changing, but no movement out of the motors...  Could this be due to not tuning them yet?  I don't have an oscilloscope and haven't done anything yet other then the initial Gecko instructions, limit is at half, gain is at zero, and damp is at 25 percent.
Offline Chip
  •  2,055 2,055
Hi, Radioactive
Make sure you have Port "1" selected in port's & pin's, Motor Output's for Dir & Step Port's.
Also do you have a Pulse Frequency showin on the Diag. screen.
Chip
« Last Edit: April 05, 2009, 11:28:57 PM by Chip »
Port 1 is selected on the ports & pins page.  However, there is no pulse freq shown.  It says "External"?
