Hello Guest it is October 26, 2026, 12:51:33 PM
Author Topic: Z axis is dead  (Read 15629 times)
Z axis is dead
« on: March 30, 2009, 07:33:28 AM »
Hello everyone,
Everything was fine until I started my SyilX4 Mill today and the Z axis is not moving.
The DROs show movement but it doesnt move.
All other axis operate normaly and in manual mode the Z also works fine.
I did not change any settings !
Any ideas on how to solve this?
  •  9,374 9,374
Re: Z axis is dead
« Reply #1 on: March 30, 2009, 08:26:32 AM »
Have you checked that your GCode program does not have the feedrate set too high ? (there is probably more load on the Z axis than the X and Y).
Re: Z axis is dead
« Reply #2 on: March 30, 2009, 01:13:30 PM »
Whast do you mean by manual mode, is that jogging via keyboard?
Please attach the xml for the profile you are using.
Re: Z axis is dead
« Reply #3 on: March 30, 2009, 04:16:00 PM »
No I mean with the handheld controller that it works ok.
From mach3 moving the cursors  I only get movement for X Y C and not for Z eventhough the DROs show movement.
Re: Z axis is dead
« Reply #4 on: March 30, 2009, 04:22:28 PM »
Is it still through Mach when using this handheld controller or is it a totally independant thing that does not require Mach?
Re: Z axis is dead
« Reply #5 on: April 02, 2009, 10:38:41 AM »
It is handheld controller externally from mach3.
Anyways I solved the problem reading through some older posts.
It was the  serial cable. I bought a new one and everything was back in order!
It seems that only pin 16 (Z for SyilX4) was damaged.
Thank you
