Hello Guest it is November 19, 2026, 02:06:23 PM
Author Topic: Mach pukes on this code.  (Read 10164 times)
« on: March 30, 2009, 04:44:40 AM »
Something to do with the Macro call at line 353. I am using Mach3 R3.042.024 and the only option I had was to disable macros in my post processor and re-generate.
I later experienced a problem with a macro call where the line following the macro return is skipped. So maybe this is related to that failure.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach pukes on this code.
« Reply #1 on: March 30, 2009, 12:50:25 PM »
It runs sweet in R3.043.000
Graham
« Reply #2 on: March 31, 2009, 05:28:44 AM »
I was told in a different thread to avoid 043 because it had some of the fixes from 042 removed as an experiment at fixing other problems.
I am running a SmoothStepper and was having problems and so I just went back to 042 to play it safe.
Can the revision history file be updated to reflect what was changed in 043? Then I could decide if it is worth trying. Macros are really nice sometimes but since this code is generated by a CAM program and there is virtually no limit to how long a program can be it isn't necessary to ever use a macro.
vmax549
« Reply #3 on: March 31, 2009, 09:13:51 AM »
I can confirm Gramhams statement, It runs fine here. I ran the code 3 time to be sure.
Just a thought, (;-)
