Hello
Guest
it is
November 19, 2026, 02:06:28 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
G-Code, CAD, and CAM
G-Code, CAD, and CAM discussions
Mach pukes on this code.
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach pukes on this code. (Read 10167 times)
boilerbots
24
on:
March 30, 2009, 04:44:40 AM »
Something to do with the Macro call at line 353. I am using Mach3 R3.042.024 and the only option I had was to disable macros in my post processor and re-generate.
I later experienced a problem with a macro call where the line following the macro return is skipped. So maybe this is related to that failure.
Logged
Graham Waterworth
2,785
Yorkshire Dales, England
Re: Mach pukes on this code.
Reply #1 on:
March 30, 2009, 12:50:25 PM »
It runs sweet in R3.043.000
Graham
Logged
boilerbots
24
Reply #2 on:
March 31, 2009, 05:28:44 AM »
I was told in a different thread to avoid 043 because it had some of the fixes from 042 removed as an experiment at fixing other problems.
I am running a SmoothStepper and was having problems and so I just went back to 042 to play it safe.
Can the revision history file be updated to reflect what was changed in 043? Then I could decide if it is worth trying. Macros are really nice sometimes but since this code is generated by a CAM program and there is virtually no limit to how long a program can be it isn't necessary to ever use a macro.
Logged
vmax549
Reply #3 on:
March 31, 2009, 09:13:51 AM »
I can confirm Gramhams statement, It runs fine here. I ran the code 3 time to be sure.
Just a thought, (;-)
Logged
Print
Pages:
1
Go Up
« previous
next »
