Hello Guest it is November 07, 2026, 01:49:51 AM
Author Topic: Macro, Engraving, COnsecutive serial numbers  (Read 34878 times)
vmax549
« on: March 28, 2009, 04:12:01 PM »
Here is a macro that will engrave consecutive serial numbers. It rREQUIRES that a new DRO be set up on your screen OEMDRO 1050.
OR NOTE this macro can be changed to use a persistant VARS instead of a new DRO to store the S/N.
Each time it is run it will increment the serial number UP one number. To reset the starting point simply reset the DRO or VAR to the new Number.
To use move to the starting point from the Number. THen call the M1500 macro. It can be called from the Gcode program or the MDI line or from a button script.
(The Depth of cut, Clear Z and spacing are adjustable from inside the Macro or can be made to be set from a macro argument if needed)
It wil start off by engraving       S/N:     then adds the serial number    IE:    S/N: 090300001  ,  next run  S/N: 090300002 , ETC
CODE EXAMPLE:
' Macro for consecutive S/N engraving from MACH
Sub main
Dim A As String
Dim Ch As String
Dim Cnt As Integer
SetVar(1303 , .250)  'LetterSpacing
Setvar(1300 , -0.005) ' Z Depth cutting
Setvar(1200 , 0.050) ' Safe Z
'CPx= Getoemdro(0)
'CPy= Getoemdro(1)
SETIJMODE(1)
Setvar(1301, getdro(0))
Setvar(1302, getdro(1))
message "S"
Code "g90 G0  Z#1200 X[#1301 + .2250] Y#1302 "
code "G91G0 x -.0706"
code " y-.0449"
code "G90 G1Z#1300 F20."
code "g91 g1X.0159Y-.0361I.05J.0004"
code "X.0375Y-.0151I.0377J.0395"
code "G1X.0348"
code "G3X.0373Y.0151I-.0001J.0539"
code "X.0157Y.0361I-.0346J.0365"
code "X-.016Y.0383I-.0551J-.0004"
code "X-.037Y.0164I-.0378J-.0356"
code "G1X-.0352"
code "G2X-.0373Y.0157I.0003J.0528"
code "X-.0157Y.0372I.0371J.0376"
code "X.0157Y.0374I.0535J-.0004"
code "X.0373Y.016I.0377J-.0365"
code "G1X.0706"
code "G90 G0Z[#1200]"
Code "G0 Z#1200 X[#1301 + .2250] Y#1302 "
While IsMoving()
Wend
message "/"
code "G91G0X.0357Y.1071"
code "G91 g1X-.1071Y-.2142"
While IsMoving()
Wend
message "N"
Code "G90  g0 X[#1301 + .2250] Y#1302 "
code "G91G0X-.0706 Y-.1078"
code "G91 g1y.2156"
code "x.1412 Y-.2156"
code "y.2156"
code "G90 G0 Z#1200"
Code "G0 Z#1200X[#1301 + .2250] Y#1302"
While IsMoving()
Wend
message ":"
code "G91G0y-.0559"
code "G90 G1Z[#1300 -.010] F20."
Code "Z#1200"
code "G91 Y.1118"
Code "Z#1200"
While IsMoving()
Wend
P10= GetOEMDRO(1050)
A=Str(P10)
For Cnt=1 To Len(A)
  Ch=Mid(A,Cnt,1)
  Select Case Ch
    Case "0" ZERO
    Case "1" ONE
    Case "2" TWO
    Case "3" THREE
    Case "4" FOUR
    Case "5" FIVE
    Case "6" SIX
    Case "7" SEVEN
    Case "8" EIGHT
    Case "9" NINE
  End Select
Next
P10=P10+1
SetOEMDRO(1050,P10)
SETIJMODE(1)
While IsMoving()
Wend
End Sub
Sub ZERO
message "Zero"
Code " G0 X[#1301 + .2250] Y#1302 "
code "G90 G0 z#1200"
code "G91 G0 X-.0004Y.1076"
code "G90 G1 Z#1300 F20."
code "G91 G1X.0176 "
code "G2X.0374Y-.0194I-.0021J-.05"
code "X.0164Y-.0417I-.0488J-.0432"
code "G1X-.0009Y-.1012"
code "G2X-.0157Y-.0372I-.0527J.0004"
code "X-.0372Y-.0157I-.0375J.0371"
code "G1X-.0353"
code "G2X-.0372Y.0157I.0004J.0528"
code "G1Y.1059"
code "G2X.0157Y.0389I.0585J-.001"
code "X.0372Y.0175I.0382J-.033"
code "G1X.0177 "
Code "G90 Z#1200"
While IsMoving()
Wend
End Sub
Sub ONE
message "One"
code "G91G0X-.0359Y.0719"
code "G91 X.0357Y.0361"
code "Y-.2156"
code "X-.0357"
code "X.0718"
While IsMoving()
Wend
End Sub
Sub TWO
message "Two"
Code "G90 G0 Z#1200 X[#1301 + .2250] Y#1302 "
code "G91G0X-.071Y.0531 "
code "G90 G1Z#1300 F20. "
code "G91 G2X.0157Y.0375I.0535J-.0004 "
code "X.0377Y.0159I.0379J-.0371"
code "G1X.0352 "
code "G2X.0375Y-.0159I-.0005J-.0531 "
code "X.0159Y-.0375I-.0373J-.038 "
code "X-.0164Y-.0383I-.0527J-.0001"
code "G1X-.1256Y-.1213"
code "X.142"
code "G90 G0Z#1200"
While IsMoving()
Wend
End Sub
Sub THREE
message "Three"
code "g90 G0 Z#1200 X[#1301 + .2250] Y[#1302 ]"
code "G91G0X-.0605Y.0917"
code "G91 G2X.0362Y.0159I.0366J-.0341"
code "G1X.034"
code "G2X.0357Y-.0159I-.0006J-.0494"
code "X.0151Y-.0379I-.04J-.0379"
code "X-.0151Y-.0379I-.0552 "
code "X-.0357Y-.0159I-.0363J.0335"
code "X.0357Y-.0159I-.0006J-.0494"
code "X-.0151Y-.0374I-.0546J.0002 "
code "G1X-.034 "
code "G2X-.0362Y.0154I.0002J.0505 "
While IsMoving()
Wend
End Sub
Sub FOUR
message "Four"
code "G91G0X.0353Y-.1059"
code "G91 Y.2117"
code "X-.1059Y-.1411"
code "X.1412"
code "G90 G0Z#1200"
While IsMoving()
Wend
End Sub
Sub FIVE
message "Five"
code "G91G0X.0714Y.1071"
code "G91 X-.1428"
code " Y-.0714"
code "X.0895"
code "G2X.0374Y-.0159I-.0005J-.0531"
code "X.0159Y-.0374I-.0372J-.0379"
code "G1Y-.0358"
code "G2X-.0159Y-.0378I-.0537J.0003"
code "X-.0374Y-.0159I-.0379J.0372"
code "G1X-.0357"
code "G2X-.0379Y.0159I.0002J.0536"
code "X-.0159Y.0374I.0372J.0379"
code "G90 G0Z#1200"
While IsMoving()
Wend
End Sub
Sub SIX
message "Six"
code "G91G0X.0555Y.091"
code "G91 G3X-.0379Y.0155I-.0376J-.038"
code "G1X-.0352"
code "G3X-.0377Y-.0159I.0002J-.053"
code "X-.0157Y-.0375I.0378J-.0379"
code "G1Y-.1062"
code "G3X.0157Y-.0377I.0533J.0001"
code "X.0377Y-.0157I.0378J.0376"
code "G1X.0352"
code "X.0375Y.0157I-.0004J.0535"
code "X.0159Y.0377I-.0371J.0379"
code "G1Y.0352"
code "G3X-.0159Y.0375I-.0531J-.0005"
code "X-.0375Y.0159I-.038J-.0372"
code "G1X-.0352"
While IsMoving()
Wend
End Sub
Sub SEVEN
message "Seven"
code "G90 z#1200"
code "G91G0X-.0714Y.1071"
code "G91 X.1428"
code "X-.1071Y-.2142"
While IsMoving()
Wend
End Sub
Sub EIGHT
message "Eight"
code "G91G0X0.Y.1061"
code "G91 X.0176"
code "G2X.0373Y-.016I-.0004J-.0525"
code "X.0157Y-.0374I-.0378J-.0378"
code "X-.0157Y-.0372I-.0528J.0004"
code "X-.0373Y-.0157I-.0376J.0371"
code "G1X-.0352"
code "G3X-.0373Y-.0164I.0005J-.0519"
code "X-.0157Y-.0383I.0398J-.0386"
code "X.0159Y-.0361I.05J.0004"
code "G1X.0348"
code "G1X-.0352"
code "G1X.0176"
While IsMoving()
Wend
End Sub
Sub NINE
message "Nine"
Code "G90 G0  Z#1200 X[#1301 +.2250] Y#1302 "
code "G91G0X-.0555Y-.091"
code "G91 G3X.0379Y-.0155I.0376J.038"
code "G1X.0352"
code "G3X.0375Y.0157I-.0004J.0535"
code "G1Y.1062"
code "G3X-.0159Y.0375I-.0532J-.0005"
code "G1X-.0352"
code "G1Y-.0352"
code "G1X.0352"
code "G90 G0Z#1200"
Code "G0  Z#1200 X[#1301 +.2250] Y#1302 "
While IsMoving()
Wend
End Sub
SETIJMODE(0)
CODE"G90"
CODE"M30"
Re: Macro, Engraving, COnsecutive serial numbers
« Reply #1 on: December 21, 2012, 01:04:33 PM »
Hello. I am familiar with Fanuc controls with regards to sequential serialization but am a bit lost with Mach3. Never used the software before but it seems like the best option, cheapest option to use an old desktop mill for some offline engraving to save machine time. Is there any way you could describe how to get the new DRO and make things work within the Mach3 interface? I have a basic idea but have had no luck poking around in the demo I downloaded earlier yesterday. Would appreciate it greatly. Thank you!
