' Macro for consecutive S/N engraving from MACH Main End Sub main Dim A As String Dim Ch As String Dim Cnt As Integer SetVar(1303 , .250) 'LetterSpacing Setvar(1300 , -0.005) ' Z Depth cutting Setvar(1200 , 0.050) ' Safe Z 'CPx= Getoemdro(0) 'CPy= Getoemdro(1) SETIJMODE(1) Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "S" Code "g90 G0 Z#1200 X[#1301 + .2250] Y#1302 " code "G91G0 x -.0706" code " y-.0449" code "G90 G1Z#1300 F20." code "g91 g1X.0159Y-.0361I.05J.0004" code "X.0375Y-.0151I.0377J.0395" code "G1X.0348" code "G3X.0373Y.0151I-.0001J.0539" code "X.0157Y.0361I-.0346J.0365" code "X-.016Y.0383I-.0551J-.0004" code "X-.037Y.0164I-.0378J-.0356" code "G1X-.0352" code "G2X-.0373Y.0157I.0003J.0528" code "X-.0157Y.0372I.0371J.0376" code "X.0157Y.0374I.0535J-.0004" code "X.0373Y.016I.0377J-.0365" code "G1X.0706" code "G90 G0Z[#1200]" Code "G0 Z#1200 X[#1301 + .2250] Y#1302 " Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "/" Code "G0 Z#1200 X[#1301 + .2250] Y#1302 " code "G91G0X.0357Y.1071" code "G90 G1Z#1300 F20." code "G91 g1X-.1071Y-.2142" code "G90 G0Z[#1200]" Code "G0 Z#1200 X[#1301 + .2250] Y#1302 " Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "N" Code "G90 g0 X[#1301 + .2250] Y#1302 " code "G91G0X-.0706 Y-.1078" code "G90 G1Z#1300 F20." code "G91 g1y.2156" code "x.1412 Y-.2156" code "y.2156" code "G90 G0 Z#1200" Code "G0 Z#1200X[#1301 + .2250] Y#1302" Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message ":" Code "G90 g0 X[#1301 + .2250] Y#1302 " code "G91G0y-.0559" code "G90 G1Z[#1300 -.010] F20." Code "Z#1200" code "G91 Y.1118" code "G90 G1Z[#1300 -.010] F20." Code "Z#1200" Code "G0 Z#1200X[#1301 + .2250] Y#1302" Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend P10= GetOEMDRO(1050) A=Str(P10) For Cnt=1 To Len(A) Ch=Mid(A,Cnt,1) Select Case Ch Case "0" ZERO Case "1" ONE Case "2" TWO Case "3" THREE Case "4" FOUR Case "5" FIVE Case "6" SIX Case "7" SEVEN Case "8" EIGHT Case "9" NINE End Select Next P10=P10+1 SetOEMDRO(1050,P10) Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) SETIJMODE(1) Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub Sub ZERO message "Zero" Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) Code " G0 X[#1301 + .2250] Y#1302 " code "G90 G0 z#1200" code "G91 G0 X-.0004Y.1076" code "G90 G1 Z#1300 F20." code "G91 G1X.0176 " code "G2X.0374Y-.0194I-.0021J-.05" code "X.0164Y-.0417I-.0488J-.0432" code "G1X-.0009Y-.1012" code "G2X-.0157Y-.0372I-.0527J.0004" code "X-.0372Y-.0157I-.0375J.0371" code "G1X-.0353" code "G2X-.0372Y.0157I.0004J.0528" code "X-.0157Y.0372I.0371J.0376" code "G1Y.1059" code "G2X.0157Y.0389I.0585J-.001" code "X.0372Y.0175I.0382J-.033" code "G1X.0177 " Code "G90 Z#1200" Code "G0 Z#1200X[#1301 + .2250] Y#1302" Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub Sub ONE Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "One" Code "G90 g0 X[#1301 + .2250] Y#1302 " code "G91G0X-.0359Y.0719" code "G90 G1Z#1300 F20." code "G91 X.0357Y.0361" code "Y-.2156" code "X-.0357" code "X.0718" code "G90 G0 Z#1200" Code "G0 Z#1200X[#1301 + .2250] Y#1302" Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub Sub TWO Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "Two" Code "G90 G0 Z#1200 X[#1301 + .2250] Y#1302 " code "G91G0X-.071Y.0531 " code "G90 G1Z#1300 F20. " code "G91 G2X.0157Y.0375I.0535J-.0004 " code "X.0377Y.0159I.0379J-.0371" code "G1X.0352 " code "G2X.0375Y-.0159I-.0005J-.0531 " code "X.0159Y-.0375I-.0373J-.038 " code "X-.0164Y-.0383I-.0527J-.0001" code "G1X-.1256Y-.1213" code "X.142" code "G90 G0Z#1200" Code "G0 Z#1200 X[#1301 + .2250] Y#1302 " Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub Sub THREE Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "Three" code "g90 G0 Z#1200 X[#1301 + .2250] Y[#1302 ]" code "G91G0X-.0605Y.0917" code "G90 G1Z#1300 F20." code "G91 G2X.0362Y.0159I.0366J-.0341" code "G1X.034" code "G2X.0357Y-.0159I-.0006J-.0494" code "X.0151Y-.0379I-.04J-.0379" code "X-.0151Y-.0379I-.0552 " code "X-.0357Y-.0159I-.0363J.0335" code "X.0357Y-.0159I-.0006J-.0494" code "X.0151Y-.0379I-.04J-.0379" code "X-.0151Y-.0374I-.0546J.0002 " code "X-.0357Y-.0159I-.0363J.0335" code "G1X-.034 " code "G2X-.0362Y.0154I.0002J.0505 " code "G90 G0Z[#1200]" Code "G0 Z#1200X[#1301 + .2250] Y#1302" Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub Sub FOUR Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "Four" Code "g90 G0 Z#1200 X[#1301 + .2250] Y#1302 " code "G91G0X.0353Y-.1059" code "G90 G1Z#1300 F20." code "G91 Y.2117" code "X-.1059Y-.1411" code "X.1412" code "G90 G0Z#1200" Code "G0 Z#1200 X[#1301 + .2250] Y#1302 " Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub Sub FIVE Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "Five" Code "G90 G0 Z#1200 X[#1301 + .2250] Y#1302 " code "G91G0X.0714Y.1071" code "G90 G1Z#1300 F20." code "G91 X-.1428" code " Y-.0714" code "X.0895" code "G2X.0374Y-.0159I-.0005J-.0531" code "X.0159Y-.0374I-.0372J-.0379" code "G1Y-.0358" code "G2X-.0159Y-.0378I-.0537J.0003" code "X-.0374Y-.0159I-.0379J.0372" code "G1X-.0357" code "G2X-.0379Y.0159I.0002J.0536" code "X-.0159Y.0374I.0372J.0379" code "G90 G0Z#1200" Code "G0 Z#1200 X[#1301 + .2250] Y#1302 " Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub Sub SIX Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "Six" Code "G90 G0 Z#1200 X[#1301 + .2250] Y#1302 " code "G91G0X.0555Y.091" code "G90 G1Z#1300 F20." code "G91 G3X-.0379Y.0155I-.0376J-.038" code "G1X-.0352" code "G3X-.0377Y-.0159I.0002J-.053" code "X-.0157Y-.0375I.0378J-.0379" code "G1Y-.1062" code "G3X.0157Y-.0377I.0533J.0001" code "X.0377Y-.0157I.0378J.0376" code "G1X.0352" code "X.0375Y.0157I-.0004J.0535" code "X.0159Y.0377I-.0371J.0379" code "G1Y.0352" code "G3X-.0159Y.0375I-.0531J-.0005" code "X-.0375Y.0159I-.038J-.0372" code "G1X-.0352" code "G3X-.0377Y-.0159I.0002J-.053" code "X-.0157Y-.0375I.0378J-.0379" code "G90 G0Z[#1200]" Code "G0 Z#1200 X[#1301 + .2250] Y#1302 " Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub Sub SEVEN Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "Seven" Code "G0 Z#1200 X[#1301 + .2250] Y#1302 " code "G90 z#1200" code "G91G0X-.0714Y.1071" code "G90 G1Z#1300 F20." code "G91 X.1428" code "X-.1071Y-.2142" code "G90 G0Z[#1200]" Code "G0 Z#1200 X[#1301 + .2250] Y#1302 " Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub Sub EIGHT Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "Eight" Code "g90 G0 Z#1200 X[#1301 + .2250] Y#1302 " code "G91G0X0.Y.1061" code "G90 G1Z#1300 F20." code "G91 X.0176" code "G2X.0373Y-.016I-.0004J-.0525" code "X.0157Y-.0374I-.0378J-.0378" code "X-.0157Y-.0372I-.0528J.0004" code "X-.0373Y-.0157I-.0376J.0371" code "G1X-.0352" code "G3X-.0373Y-.0164I.0005J-.0519" code "X-.0157Y-.0383I.0398J-.0386" code "X.0159Y-.0361I.05J.0004" code "X.0375Y-.0151I.0377J.0395" code "G1X.0348" code "G3X.0373Y.0151I-.0001J.0539" code "X.0157Y.0361I-.0346J.0365" code "X-.016Y.0383I-.0551J-.0004" code "X-.037Y.0164I-.0378J-.0356" code "G1X-.0352" code "G2X-.0373Y.0157I.0003J.0528" code "X-.0157Y.0372I.0371J.0376" code "X.0157Y.0374I.0535J-.0004" code "X.0373Y.016I.0377J-.0365" code "G1X.0176" code "G90 G0Z[#1200]" Code "G0 Z#1200 X[#1301 + .2250] Y#1302 " Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub Sub NINE Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) message "Nine" Code "G90 G0 Z#1200 X[#1301 +.2250] Y#1302 " code "G91G0X-.0555Y-.091" code "G90 G1Z#1300 F20." code "G91 G3X.0379Y-.0155I.0376J.038" code "G1X.0352" code "G3X.0375Y.0157I-.0004J.0535" code "X.0159Y.0377I-.0371J.0379" code "G1Y.1062" code "G3X-.0159Y.0375I-.0532J-.0005" code "X-.0375Y.0159I-.038J-.0372" code "G1X-.0352" code "G3X-.0377Y-.0159I.0002J-.053" code "X-.0157Y-.0375I.0378J-.0379" code "G1Y-.0352" code "G3X.0157Y-.0377I.0533J.0001" code "X.0377Y-.0157I.0378J.0376" code "G1X.0352" code "G3X.0375Y.0157I-.0004J.0535" code "X.0159Y.0377I-.0371J.0379" code "G90 G0Z#1200" Code "G0 Z#1200 X[#1301 +.2250] Y#1302 " Setvar(1301, getdro(0)) Setvar(1302, getdro(1)) While IsMoving() Wend End Sub SETIJMODE(0) CODE"G90" CODE"M30"
